Topic "Change permissions on files and directories"
lloyd_borrett
G'day,
I've used WinSCP to transfer a Tar/GZip from a Windows XP system to a Linux system.
When expanded to the Linux system, the permissions on files are set to 640 not 644, and the directories aren't being set to 755.
Is there a way to specify this in WinSCP?
Or is there a way to quickly change a complicated directory structure to have files set to 644 and directories to 755?
I've already worked out how to change the permissions manually. But it's not a practical solution if the structure transferred is complicated. Can you imagine how long it would take to go through say a phpBB or WordPress install and change the permissions of all of the files and directories manually?
Would there be a way using WinSCP, to recursively go through a directory structure and set files to 644 and directories to 755?
Or if not using WinSCP, some other solution?
Best Regards, Lloyd Borrett.
Use change properties function, set the permissions to 644 and make sure the Add X to directories option is enabled.
marty.mcgee
This works! Just make sure to also check Set group, owners, and permissions recursively so that this happens to all sub-files and sub-directories: sub-files are assigned 0644 and sub-directories are assigned 0755 (which is 0644 plus 0111, or "X on directories"). Perfect, thanks!
