Topic "event logging"
nickguido
when i go to the logging tab I am not presented with a choice for logging, As such, I can't enable logging. did i do something wrong during install? What do you suggest?
So what do you have on the Logging tab?
nickguido
I found the logging tab. It's not what I need. I am trying to generate a log file in scripting mode. I tried to use the /log command but it seems to be ignored. I tried to add la log command to the script, but that doesn't work either.
when the script runs,a window appears on the screen. Can I capture the contents of the window and can I pause the sereen to view the results during testing? Is there another way capture the events?
/log should work. What version of WinSCP are you using? Can you post an example of command you use to run WinSCP?
nickguido
The following line appears within a dos batch file run on a windows 2000 server. We are using WinSCP 3.7.4 build 271
"c:\program files\winscp3\winscp3.exe" /console /script=D:\WEBOUT\NSS_Scripts\winscp3_to_NSS.txt /log=D:\LogFiles\nss\to_NSS.txt
(script file) (winscp3_to_NSS.txt)
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
option log=D:\LogFiles\nss\to_NSS.txt
# Connect using a password
# open user:password@example.com
# Connect
# Change remote directory
# cd /home/user
lcd d:/temp
# Force binary mode transfer
option transfer binary
# Download file to the local directory d:\
# get examplefile.txt d:\
# Disconnect
#close
# Connect as a different user
open ops13400@nssfdtstv.wan.newspapersupport.com
# Change the remote directory
cd /app/iface/NSFSCNV/13400/AP/inbound
# Upload the file to current working directory
put SIAPIo57
put SIAPIo58
put SIAP01
put SIAP02
put NSAP01
put NSAP02
#put d:\examplefile.txt
dir
# Disconnect
close
# Exit WinSCP
/log is supported since 3.8.2 only.
