Topic "how to set option include & exclude"
TK2006
Hello Group,
i want only to synchronize a specific file extension but this does not work. Here is my script:
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect using a password
# open user:password@example.com
# Connect
open wtrends:u2bono@gcfpwbapeu1p-eth0.eurdmz.dmzroot.net
# Change remote directory
# cd /lhome/wtrends/JFPPT/
# option transfer binary
# get access*.gz
# cd /opt/SUNWwbsvr/https-host-eth0.eurdmz.dmzroot.net/logs/
# get access*
option include access*
synchronize local e:\Tempa /opt/SUNWwbsvr/https-host-eth0.eurdmz.dmzroot.net/logs
# Disconnect
#close
# Exit WinSCP
#pause
#exit
Any clue?!?
Thanks in advance
What does not work? How does it behave and what do you expect instead?
tk2006
I want all files errors* exluded or access* included.
Your script should do that. If not, please post a log file.
From the server, or client?
Client.
tk2004
I have resolved, thank you again Very Happy
Another question, following file is used as download file.
option batch on
# Connect
open wtrends:u2bono@host
synchronize local G:\raw\UK_JFP_Light\host /opt/SUNWwbsvr/https-host/logs
# Disconnect
close
# Exit WinSCP
Now i have some servers where i can only connect hostbased with genericuser and hostkey. Where do i have to set the /privatekey= setting?
Can you give me a short example?
Many thanks in advance
tko2004
Any clue...
Sorry, I remember I have replied to your question, but it's gone Sad
The /privatekey setting is a command-line option.
