Topic "schedualing and password confirm"
pelegk2
i am trung to write a scheduale that will open the winscp3 software and copu a file from 1 server to another
itried to do it like in the FAQ but the password keep's om prompting (i am doing it on from winxp to win2003 server for test but later it will be from one win2003 server to another)
this is the line written in the "RUN" command :
C:\PROGRA~1\WinSCP3\WinSCP3.exe "open user:pass$$@100.10.10.11"  "c:\WG.PRN  /backup"   "exit"
all the quote marks i hhope there are ok?!?!?
the source folder if from the C and the destination is the destination SFTP folder and there to a sub folder called backup
can any 1 help?
thnak in advance
peleg
The correct command may be:
C:\PROGRA~1\WinSCP3\WinSCP3.exe /command "open user:pass$$@100.10.10.11" "put c:\WG.PRN /backup/" "exit"
pelegk2
but it still popups for a password !
maybe something in the sofwate as it installed or configured make me the problem>
thnaks i nadvance
peleg
thnaks i nadvance
If you run it as above it cannot ask for password as there is no GUI unless you also use the /console parameter. Or unless you use some old version of WinSCP. So what version do you use?
pelegk2
i have a GUI which i use to manualy chhose files and transfer???
or i miss understand something?!?!
the version is 3.7.5
any idea?
With 3.7.5 you need to add /console parameter. But you are definitely advised to upgrade.
pelegk2
that instead of using WinSCP3.com i used WinSCP3.exe !!!
