Topic "Keep control of file transfer"
natha
I am using WinSCP in MS SQL Server DTS package to download files from remote to local server on daily basis.
I am doing it this way in the script file:
# Download file(s) to the local directory d:\
get *.txt c:\BaseCDR\
# Delete downloaded file(s)
rm *.txt
Is there a way to control that the files have been properly downloaded before removing them from remote server?
Consider following:
1. I cannot use remote recycle bin.
2. It has no sense to count the downloaded files on local side, since the amount of files may vary.
3. Is there any way to retrieve number of files on remote server (compare local with remote)?
Thanx in advance for your reply.
Use "option batch abort" to abort the script in case "get" fails.
Ren
I'm using WinSCP 3.8.2 standalone, and have the following script:
<script>
# abort on error
option batch abort
# switch to download directory
cd /download
# set transfer mode to ascii
option transfer ascii
# download the report files
get *.dat
# clear the download directory
rm *.dat
# disconnect
close
# exit WinSCP
</script>
When a file exists in the target dir, the get command will issue an overwrite command and fail. However, the script continues with the next step, which clears the download directory. Given the 'option batch abort', I would not expect this, and do not want this. Your previous reply also indicates this should work.
How can I make the script really bail out when the get command fails?
Thanks.
Abort of file transfer in case the remote file exists and overwrite is not allowed is not considered a failure. I can understand you do not like that. But it is designed so.
