Topic "Why does GSSAPI auth require a username?"
Great job on the UI. It works great with kerberos as well. My only gripe is why do I have to enter a username if the software has my ticket? It should default to use my UPN. Unfortunately, the login button doesn't activate until I enter something in that text field. Can we activate the login button when kerberos is selected, and then use the UPN if the username field is empty?
Thanks for pointing me to the problem. I'll check that.
