Topic "Timeout waiting for external console to complete the command"
RickB
I am getting the following Error:
I am using v3.8.2 (build 330).
I am running the following command (from WScript.Shell exec()):
winscp3.com /command "open xxxxx@yyyy" "cd /apps" "ls" "close" "exit"
If there are more than about ten files in the directory the command partially works (I get get part of the file listing) but times out before it completes.
Have tried using keepalives and setting server timeout to 120 but it hasn't helped.
Help?
Can you post full output of the WinSCP?
RickB
Dobry den Martin
All I get is an alert dialog, the title says "Error" and the error is
"Timeout waiting for external console to complete the command."
Below is what I get in the log file:
Any idea how I could fix this?
Dekuji
Rick
. 2006-12-11 08:01:21.927 --------------------------------------------------------------------------
. 2006-12-11 08:01:21.937 WinSCP Version 3.8.2 (Build 330) (OS 5.1.2600 Service Pack 1)
. 2006-12-11 08:01:21.947 Login time: Monday, 11 December 2006 8:01:21 AM
. 2006-12-11 08:01:21.947 --------------------------------------------------------------------------
. 2006-12-11 08:01:21.947 Session name: xxxxxxx@xxxxxxxxx
. 2006-12-11 08:01:21.957 Host name: xxxxxxxxx (Port: 22)
. 2006-12-11 08:01:21.957 User name: xxxxxxx (Password: Yes, Key file: No)
. 2006-12-11 08:01:21.967 Transfer Protocol: SFTP (SCP)
. 2006-12-11 08:01:21.967 SSH protocol version: 2; Compression: No
. 2006-12-11 08:01:21.977 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2006-12-11 08:01:21.977 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2006-12-11 08:01:21.977 Ping type: -, Ping interval: 15 sec; Timeout: 120 sec
. 2006-12-11 08:01:21.987 SSH Bugs: -,-,-,-,-,-,-,-
. 2006-12-11 08:01:21.987 SFTP Bugs: -,-,-
. 2006-12-11 08:01:21.987 Proxy: none
. 2006-12-11 08:01:21.997 Return code variable: Autodetect; Lookup user groups: Yes
. 2006-12-11 08:01:21.997 Shell: default, EOL: 0
. 2006-12-11 08:01:21.997 Local directory: G:\xxxxxx, Update: No, Cache: Yes
. 2006-12-11 08:01:22.007 Cache directory changes: Yes, Permanent: Yes
. 2006-12-11 08:01:22.007 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2006-12-11 08:01:22.007 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2006-12-11 08:01:22.017 --------------------------------------------------------------------------
. 2006-12-11 08:01:22.017 Looking up host "xxxxxxxxx"
. 2006-12-11 08:01:22.057 Connecting to xxx.xxx.xxx.xxx port 22
. 2006-12-11 08:01:22.087 Server version: SSH-1.99-OpenSSH_4.3p2-hpn
. 2006-12-11 08:01:22.087 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2006-12-11 08:01:22.097 Using SSH protocol version 2
. 2006-12-11 08:01:22.107 Doing Diffie-Hellman group exchange
. 2006-12-11 08:01:22.117 Doing Diffie-Hellman key exchange
. 2006-12-11 08:01:22.538 Host key fingerprint is:
. 2006-12-11 08:01:22.538 ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx
. 2006-12-11 08:01:22.538 Initialised AES-256 client->server encryption
. 2006-12-11 08:01:22.548 Initialised HMAC-SHA1 client->server MAC algorithm
. 2006-12-11 08:01:22.558 Initialised AES-256 server->client encryption
. 2006-12-11 08:01:22.568 Initialised HMAC-SHA1 server->client MAC algorithm
! 2006-12-11 08:01:22.638 Using username "xxxxxxx".
! 2006-12-11 08:01:22.648 SECURITY NOTICE
! 2006-12-11 08:01:22.658 Use of this system, its equipment, and resources is monitored at all
! 2006-12-11 08:01:22.668 times. All programs and information held on this system are private and
! 2006-12-11 08:01:22.668 confidential, and are only lawfully available to authorised users for
! 2006-12-11 08:01:22.668 authorised purposes only.
! 2006-12-11 08:01:22.688 It is a criminal offence to obtain unauthorised access to any program
! 2006-12-11 08:01:22.688 or information within this system and/or to make any unauthorised
! 2006-12-11 08:01:22.698 modifications whatsoever to the contents of this computer system.
! 2006-12-11 08:01:22.698 If you are not an authorised user you are violating the regulations of
! 2006-12-11 08:01:22.698 this system and can, and will be prosecuted to the full extent of the
! 2006-12-11 08:01:22.708 law. Please disconnect immediately.
. 2006-12-11 08:01:22.708 Keyboard-interactive authentication refused
. 2006-12-11 08:01:22.708 Session password prompt (xxxxxxx@xxxxxxxxx's password: )
. 2006-12-11 08:01:22.718 Using stored password.
! 2006-12-11 08:01:22.718 Authenticating with pre-entered password.
. 2006-12-11 08:01:22.718 Sent password
. 2006-12-11 08:01:22.728 Access granted
. 2006-12-11 08:01:22.739 Opened channel for session
. 2006-12-11 08:01:22.749 Started a shell/command
. 2006-12-11 08:01:22.749 --------------------------------------------------------------------------
. 2006-12-11 08:01:22.749 Using SFTP protocol.
. 2006-12-11 08:01:22.759 Doing startup conversation with host.
> 2006-12-11 08:01:22.759 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2006-12-11 08:01:22.769 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2006-12-11 08:01:22.769 SFTP version 3 negotiated.
. 2006-12-11 08:01:22.769 We believe the server has signed timestamps bug
. 2006-12-11 08:01:22.779 We will use UTF-8 strings for status messages only
. 2006-12-11 08:01:22.779 Limiting packet size to OpenSSH limit of 262148 bytes
. 2006-12-11 08:01:22.789 Changing directory to "/apps/xxx".
. 2006-12-11 08:01:22.789 Getting real path for '/apps/xxx'
> 2006-12-11 08:01:22.789 Type: SSH_FXP_REALPATH, Size: 57, Number: 16
< 2006-12-11 08:01:22.799 Type: SSH_FXP_NAME, Size: 117, Number: 16
. 2006-12-11 08:01:22.799 Real path is '/apps/xxx'
. 2006-12-11 08:01:22.809 Trying to open directory "/apps/xxx".
> 2006-12-11 08:01:22.809 Type: SSH_FXP_LSTAT, Size: 57, Number: 263
< 2006-12-11 08:01:22.819 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2006-12-11 08:01:22.819 Getting current directory name.
. 2006-12-11 08:01:22.819 Startup conversation with host finished.
. 2006-12-11 08:01:22.849 Cached directory change via "/apps/xxx" to "/apps/xxx".
. 2006-12-11 08:01:22.849 Getting current directory name.
. 2006-12-11 08:01:22.849 Listing directory "/apps/xxx".
> 2006-12-11 08:01:22.859 Type: SSH_FXP_OPENDIR, Size: 57, Number: 523
< 2006-12-11 08:01:22.859 Type: SSH_FXP_HANDLE, Size: 13, Number: 523
> 2006-12-11 08:01:22.919 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2006-12-11 08:01:22.939 Type: SSH_FXP_NAME, Size: 15949, Number: 780
> 2006-12-11 08:01:22.949 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< 2006-12-11 08:01:22.949 Type: SSH_FXP_STATUS, Size: 28, Number: 1036
< 2006-12-11 08:01:22.959 Status/error code: 1
> 2006-12-11 08:01:22.959 Type: SSH_FXP_CLOSE, Size: 13, Number: 1284
. 2006-12-11 08:01:32.996 Closing connection.
Can I have a contact to you, so I can send you a debug version?
RickB
Hi Martin
That would be great.
My email is:
REMOVETHIS r i c k . b r o w n ZNAK i m m i . g o v . a u ANDREMOVETHIS
I dare not post my email address in its pure form here, you'll have to remove the spaces etc.
Cheers
Rick
RickB
Hi Martin
Thanks for the debug version.
I thought I should let you know that I have found the bug and it wasn't WinSCP!
Thanks again Martin.
Cheers
Rick
If you want a more detailed explanation of the bug, read on:
I was launching WinSCP like this:
var objShell = new ActiveXObject("WScript.Shell");
var objWshScriptExec = objShell.Exec(prog);
I was then trying to read stdErr and stdOut like this:
while(!objWshScriptExec.StdErr.AtEndOfStream)
strOutput += "\n" + objWshScriptExec.StdErr.ReadAll();
while(!objWshScriptExec.StdOut.AtEndOfStream)
strOutput += "\n" + objWshScriptExec.StdOut.ReadAll();
Anyway, the script would hang reading stdErr when there were a lot of files being processed by WinSCP. The moment I stopped reading stdErr the script (and WinSCP) ran perfectly!
The problem was reported by WinSCP (I think it would timeout because suddenly it could not write to stdErr or stdOut anymore) which is why it seemed like a WinSCP bug.
Thanks for letting me know!
Hi Martin
First ... thx. for a GREAT program. I'll try to make my company donate.
Second.. I actually think there IS a bug - at least in 3.8.0.
I have exactly the same problem as reported here if ALL the following is true:
1. I use a script to execute the command line. (In my case PrintNetT script)
2. If there are more than between 42 and 59 files to be sent, using "*.*" from a directory. - I haven't narrowed it down more than this. If I have fewer than 42 files in the directory there is no problem.
3. If I try to read the ouput lines generated from WinSCP.
I do not get the problem if
1. There are fewer files than approx. 42.
2. If I use a windows command prompt only with exactly the same command.
By the way - the command I call from the script is this:
winSCP3 mySessionID /command "option batch abort" "option confirm off" "put mydir\*.*" close exit /log="c:\SFTPlogDag&amp;D.txt"
I think WinSCP tries to access the shell or something after sending the 42 (or perhaps 5Cool files.
I don't really need to read the response, so I can live with this, but I thought that you'd like to know that there is an issue here.
thx. again for a truly great program. - I am pleased to see that you have implemented FTP. I didn't know that untill I had this problem, so I guess that something good have come out of this for me.
Best Regards
Henrik Noerby
Thanks for information!
pshaw
I'm new to scripting winscp, I'm running this in task scheduler:
WinSCP.com /script=completed_sync_script.txt sync
Here's the script:
option synchdelete on
option batch continue
synchronize local "C:\sync directory" "sync"
The script runs for an hour and is then terminated by the scheduler.
It repeats this routine every hour.
You are missing "exit" command at the end.
pshaw
is there any way to time delay the exit command?
Not directly. But you can call remote command that causes delays. The simplest would be "call sleep 10".
Sunil Somani
Hi Prikryl et'al,
I have recently moved to WinSCP.
And when I need to download some file not more than 10 even, I am getting same error.
I am attaching the terminal output for your reference.
Please advise as its quite critical for me.
C:\Program Files\WinSCP>"C:\Program Files\WinSCP\winscp" /console -script=ftpSG
X091207.txt /log=SGXNightLog.txt
batch on
confirm off
Searching for host...
Connecting to host...
Authenticating...
Using username "sshdcs25001".
Authenticating with public key "rsa-key-20090915".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] sshdcs25001@167.168.15.26
/SUNIL/091207
TransferFile1 | 57 KiB | 11.9 KiB/s | binary | 100%
TransferFile2 | 57 KiB | 11.1 KiB/s | binary | 100%
TransferFile3 | 57 KiB | 10.6 KiB/s | binary | 100%
TransferFile4 | 57 KiB | 9.6 KiB/s | binary | 100%
TransferFile5 | 71 KiB | 11.1 KiB/s | binary | 100%
TransferFile6 | 71 KiB | 13.5 KiB/s | binary | 100%
TransferFile7 | 71 KiB | 15.6 KiB/s | binary | 100%
TransferFile8 | 71 KiB | 16.5 KiB/s | binary | 100%
TransferFile9 | 112 KiB | 13.5 KiB/s | binary | 100%
TransferFile10 | 112 KiB | 11.3 KiB/s | binary | 100%
TransferFile11 | 112 KiB | 12.9 KiB/s | binary | 100%
TransferFile12 | 0 KiB | 12.9 KiB/s | binary | 0%
Could you please advise what can I do to avoid such issue.
There are not even too large number of file not even in size.
Sunil Somani
Have you checked the tracker link above?
Sunil Somani
Yes, I read. And I guess you are referring "Henrik Noerby"'s reposne.
However I am not really clear what should I avoid to resolve this issue.
As its not frequent and second its not even exit, until someone hit enter or some action on the command prompt.
I don't have files more than 42, infact so far less then 20 only.
Please advise.
Sunil Somani
So how do you execute the WinSCP?
MCS
"Timeout waiting for external console to complete the command".
I try to use WinSCP (Version 4.2.7 Bilid 758) as a process object in my .Net 3.5 program. I get a pop-up dialog with the above message on random basis.
CODE:
Dim winscp As Process = New Process
winscp.StartInfo.FileName = "ApplicationPath\winscp.com"
winscp.StartInfo.UseShellExecute = False
winscp.StartInfo.RedirectStandardInput = True
winscp.StartInfo.RedirectStandardOutput = True
winscp.StartInfo.CreateNoWindow = True
winscp.Start()
winscp.StandardInput.WriteLine("option batch abort")
winscp.StandardInput.WriteLine("option confirm off")
winscp.StandardInput.WriteLine(String.Format("open {0}://{1}:{2}@{3}:{4} -timeout=100", "SFTP", Username, Password, Hostname, PortNumber))
winscp.StandardInput.WriteLine(String.Format("cd {0}", RemotePath))
winscp.StandardInput.WriteLine(String.Format("lcd {0}", LocalPath))
winscp.StandardInput.WriteLine("get " + FileName + "")
winscp.StandardInput.WriteLine("close")
winscp.StandardInput.WriteLine("exit")
winscp.StandardInput.Close()
Output = winscp.StandardOutput.ReadToEnd()
winscp.WaitForExit()
Please provide solution to this problem.
I have sent you a debug version.
Carlos Cuenca
I run winscp from a windows shell script with the following command:
Set shell = WScript.CreateObject("WScript.Shell")
Set ejecucion=shell.Exec("C:\PROGRA~2\WinSCP\winscp.com /log="+fichero+".xml /script=script.txt")
Do While ejecucion.Status = 0
WScript.Sleep 3000
Loop
WScript.Sleep 3000
Loop
If your script has long output, then it is probably still the same problem
I have updated the WSH example with alternative code not suffering the problem.
See article on "Timeout waiting for external console to complete the command" error.
