Topic "Problems after editing files"
Zap
winscp (V 4.0.0.0 Build 342) on WinXP Pro SP2
When I have edited a file in winscp, I get prompted for login and pwd which is all fine but then winscp hangs like this
The file gets updated and uploaded as it should but I have to use task manager in order to kill winscp.
Otherwise I LOVE this program!
Thanks A Lot Martin!
What if you specify username and password on login dialog and check option "remember password for brackground transfers"? Would it prevent winscp hanging?
zap
That did the trick!
Thx
