Topic "Setup"Access violation 004096DA. Write of address 00401000.""
k0t
Hi!
Every time I'm trying to run the WinSCP-Setup exe im getting the error message:
When I press "OK" the setup is being canceled!
I was even trying to install older versions which I still had on my disk, but the same error.
I hope somebody can help me to solve this problem.
Thanks in advance!
Can you try to install some very old version (like 3.0)? You can download it here.
k0t
Was able to run the 3.0 Setup....that's weird. Shocked
OK. Can you, step by step, try to install later versions to find out the one that introduced the problem?
k0t
Sure, gimme some minutes! Smile
k0t
The problem first occurs with verion 3.4.
Can run the setup of 3.3 without any problems.
Thanks. 3.4 was the first localized version, which one have you tried? winscp340setup.exe or winscp340setupintl.exe? Can you try both?
k0t
I will try when I get back home. Smile
k0t
Both are giving me that error...
Thanks. I'll check it. Can you send me your email address?
k0t
I added you in ICQ.
By the way, I'm getting this problem with another program on another computer too... Oo
k0t
I know how to solve the problem now....lol
I just had to close all open programs and tadaaaaa - it works!
Thank you for the help! Smile
You are missing a vital windows file. Not joking. I had this problem too (although different setup)
Run
sfc /scannow
