Script GET Multiple Remote Files to One Local
Griffman
Minneapolis, MN
Greetings all:
I am new to your product but am testing it for an application we have. In a script environment can the GET command be used to retrieve multiple unknown file names on the remote server and then accumulate and write to a single file on the local side? This is with WinSCP v3.8.2 connecting with SFTP (SSH protocol 2).
TIA and best regards.
Griffman in Minneapolis
Re: Script GET Multiple Remote Files to One Local
No. but you can download all the files and use simple batch file to make one of them. Check your Windows documentation for "for" and "copy" commands.
