Topic "winscp does not start from commandline"
gst
if i start winscp3.exe (Version 3.8.2) in the follow way
winscp3.exe user:password@10.10.10.10
and the password contains a "%" than winscp doesnt start.
You need to use %25 instead of simple %
gst
hey
there are more and more characters which can not used in commandline in the field password.
why can i not use "%" or "+" in field password is this a problem with programming?
can you create a version we can use all characters.
thanks
thanks
The reason is that WinSCP treats the command line parameter as an URL address. So characters that need to be escaped in an URL needs to be escaped in command-line.
GST
Is there a posibility that Winscp escapes the characters?
What's the point?
