Topic "Default LocalDirectory"
Firenight
I've a problem, i want to change my default local directory for all new session i create.
I know i can modify it into session key after create a new session or by indicate it when i create a new session.
But i want to change it for all new session without have to do something during a new session creation.
Thanks in advance for answer.
Noah
Edit this registry key on your HOST machine:
HKEY_LOCAL_MACHINE > SOFTWARE > Cygnus Solutions > Cygwin > mounts v2 > /
Name: native | Type: REG_SZ | Data: C:\whatever\path
Cheers.
Firenight
Thanks, for trying to help me.
I believe you speak about cygwin, i speak about WinSCP
I'm looking at the adress you give me and it doesn't exist in my registry.
Thanks in advance.
To change a defaults for sessions, use Set defaults button ion login dialog.
Firenight
That's right with standard version Surprised
However we have modified code to avoid user to create session so we never have session key into our registry, consequently i can't use this method Sad
But for the first one session if we put nothing he uses a default directory and i just want to change this one.
When you use your program you should not create a session but just connect and you re place in a local directory. If you see in registry there is no session key at this moment however you ve default directory for local directory.
I know i ve some problems to explain correctly the problem Surprised)
If you have you own version of WinSCP, you can change the default in code.
WinSCP uses by default the "my documents" folder of Windows.
Firenight
Ok thanks,
I thought that maybe there is a registry key for default folder.
So I'm going to modify code.
