login error when pageant has 2 keys stored
ths
Germany
Hallo,
I have a problem with 3.8.2 and 4.0.3. If I load only one key in pageant I can login to an AIX machine.
If pageant has 2 keys in memory, the connection fails.
Strangely enough this only happens for one machine, a similar machine with same AIX (5200-02) and sshd version does not exhibit this behaviour, I can login there even if pageant has 2 keys in memory.
In "View keys" the wrong key which does not match the public key on AIX is listed first, but I cannot tell if this matches the "key #0" from the logfile below (although I guess so):
Connecting to 10.132.11.132 port 22
Server version: SSH-1.99-OpenSSH_3.4p1
We claim version: SSH-2.0-WinSCP_release_4.0.3
Using SSH protocol version 2
Doing Diffie-Hellman group exchange
Doing Diffie-Hellman key exchange
Host key fingerprint is:
ssh-rsa 1024  xx:xx:...
Initialised AES-256 client->server encryption
Initialised HMAC-SHA1 client->server MAC algorithm
Initialised AES-256 server->client encryption
Initialised HMAC-SHA1 server->client MAC algorithm
Using username "root".
Reading private key file "C:\home\ths\username.ppk"
Pageant is running. Requesting keys.
Pageant has 2 SSH-2 keys
Trying Pageant key #0
Server unexpectedly closed network connection
(ESshFatal) Server unexpectedly closed network connection
Authentication failed.
Re: login error when pageant has 2 keys stored
It is possible that the server does not allow you more that one authentication attempt. Try to specify the correct key explicitly on login dialog.
anup.ramjeet.singh
Winscp Error
. 2016-11-23 22:25:02.007 Timeout waiting for network events
. 2016-11-23 22:25:02.507 Pooling for data in case they finally arrives
. 2016-11-23 22:25:02.507 Looking for network events
. 2016-11-23 22:25:02.507 Timeout waiting for network events
. 2016-11-23 22:25:03.020 Pooling for data in case they finally arrives
. 2016-11-23 22:25:03.020 Looking for network events
. 2016-11-23 22:25:03.020 Timeout waiting for network events
. 2016-11-23 22:25:03.521 Pooling for data in case they finally arrives
. 2016-11-23 22:25:03.521 Looking for network events
. 2016-11-23 22:25:03.521 Timeout waiting for network events
. 2016-11-23 22:25:04.034 Pooling for data in case they finally arrives
. 2016-11-23 22:25:04.034 Looking for network events
. 2016-11-23 22:25:04.034 Timeout waiting for network events
. 2016-11-23 22:25:04.534 Pooling for data in case they finally arrives
. 2016-11-23 22:25:04.534 Looking for network events
. 2016-11-23 22:25:04.534 Timeout waiting for network events
. 2016-11-23 22:25:05.048 Pooling for data in case they finally arrives
. 2016-11-23 22:25:05.048 Looking for network events
. 2016-11-23 22:25:05.048 Timeout waiting for network events
. 2016-11-23 22:25:05.548 Pooling for data in case they finally arrives
. 2016-11-23 22:25:05.548 Looking for network events
. 2016-11-23 22:25:05.548 Timeout waiting for network events
. 2016-11-23 22:25:06.062 Pooling for data in case they finally arrives
. 2016-11-23 22:25:06.062 Looking for network events
. 2016-11-23 22:25:06.062 Detected network event
. 2016-11-23 22:25:06.062 Enumerating network events for socket 908
. 2016-11-23 22:25:06.062 Enumerated 1 network events making 1 cumulative events for socket 908
. 2016-11-23 22:25:06.062 Data has arrived, closing query to user.
. 2016-11-23 22:25:06.067 Handling network read event on socket 908 with error 0
. 2016-11-23 22:25:06.067 Offered public key
. 2016-11-23 22:25:06.067 Waiting for the server to continue with the initialization
. 2016-11-23 22:25:06.067 Looking for incoming data
. 2016-11-23 22:25:06.067 Looking for network events
. 2016-11-23 22:25:06.335 Detected network event
. 2016-11-23 22:25:06.335 Enumerating network events for socket 908
. 2016-11-23 22:25:06.335 Enumerated 1 network events making 1 cumulative events for socket 908
. 2016-11-23 22:25:06.335 Handling network read event on socket 908 with error 0
! 2016-11-23 22:25:06.335 Server refused our key
. 2016-11-23 22:25:06.368 Server refused our key
. 2016-11-23 22:25:06.368 Selecting events 0 for socket 908
. 2016-11-23 22:25:06.368 Disconnected: No supported authentication methods available (server sent: publickey)
* 2016-11-23 22:25:06.423 (EFatal) Disconnected: No supported authentication methods available (server sent: publickey)
* 2016-11-23 22:25:06.423 Authentication log (see session log for details):
* 2016-11-23 22:25:06.423 Using username "anuprs".
* 2016-11-23 22:25:06.423 Server refused our key.
* 2016-11-23 22:25:06.423 Authentication failed.
Generated the private key from the existing private key using a tool putty key generater.
Getting an error
