Topic "cant delete anything...."
ok i try but i cant do it i get this error..
Command 'rm -f -r "VRecord.app"'
failed with return code 126 and error message
-sh: line 96: /bin/rm: Permission denied.
can anyone help me..????
I find the lack of activity about this question... disturbing.
I'm having the EXACT same problem. I'm logged in as root, yet I can't delete any apps. If anybody knows the answer to this, it would be greatly appreciated if someone posted the answer. Remeber, this stuff was new to YOU once, remember? Smile
If you're using WinSCP to manipulate files on an iPhone, you need to make sure you have rm in your /bin folder. Right click on the rm file, select Preferences, then change the octal number from 0644 to 0777. Then click ok.
If you don't have rm, see this site, http://www.hacktheiphone.com/iphone_install_ssh_windows.html
and look for Step 17 for a link to a collection of Unix bin files that you can install on the iPhone (including rm).
