Topic "4.0.3 and scripting issue"
xnih
This script worked fine in 3.82 on another box, but on this box, running 4.0.3 I get a host not found problem every time I try to run it:
option batch on
open somesite@somewhere.com
option transfer binary
put c:\test.txt
close
running with the command line:
winscp.exe /script=c:\script.txt
When watching it it appears to be trying to connect to /script as the host instead of what is in the script. If I change it to do something like:
winscp.exe someone@somehost.com /script=c:\script.txt
it will connect fine to the host, but it will not run the script.
Something change in the 4.x code that I missed, or am I just going crazy here?
For me it works fine. Can you post a log file?
