Topic "Server not found - millenium box"
gmcfarlane
We connect to a scp server and have been doing so for 1 year+, no problems.
One of the clients is a Millenium machine (ugh) and it recently developed a problem. It seems that it cant find the host.
The other client is an XP box and it continues to work.
I have verified all the settings are the same between the two boxes.
I am told nothing significant has been changed on the Millenium box.
I can not ping from either box.
I can ping google.com from both boxes.
I can open a telnet session (port 22) to the server from the XP box, not from the Milennium box.
The server is up, we can get/put files from XP box.
I do not beleive there is a firewall on this machine. I can not find one. Any ideas?
greg
here is the redacted log file...
. WinSCP Version 3.7.2 (Build 262) (OS 4.90.73010104)
. Login time: Monday, August 13, 2007 8:39:38 PM
. Session name: vengxm@ccc.aaa.bbb.edu
. Host name: ccc.aaa.bbb.edu (Port: 22)
. User name: vengxm (Password: No, Key file: Yes)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-
. SFTP Bugs: -,-
. Proxy: none
. Shell: default, EOL: 0
. Cache directory changes: Yes, Permanent: Yes
. Looking up host "ccc.aaa.bbb.edu"
* (ESshFatal) Host does not exist
