Topic "WinSCP Portable 4.0.3 Released (Works on USB w/ PuTTY)"
JohnTHaller
I've just posted the stable release of WinSCP Portable 4.0.3 after completing the public beta. This package of WinSCP is in PortableApps.com Format for easy installation to any portable device (iPod, USB flash drive, portable hard drive, etc) and integration with the PortableApps.com Suite, the most popular portable platform. WinSCP Portable automatically integrates with PuTTY Portable so you can have one-click access to a PuTTY session.
WinSCP Portable homepage
I also created some higher-res icons which I've posted here:
http://winscp.net/forum/viewtopic.php?p=15786
Regards,
John
Note that WinSCP itself is portable too.
JohnTHaller
prikryl wrote:
Hi Martin. We're aware, but the PortableApps.com Format package has a number of advantages.
    TRANSLATIONS - The PAF package includes the translations from the local version which the user can choose whether or not to install within the installer
    EASY INSTALLER - The installer automatically detects an existing install of the PortableApps.com Platform and installs into it
    DATA SEPARATION - The data is separated from the app by default in a folder that can be easily picked up by the PortableApps.com Backup utility
    PRE-CONFIGURED - It's pre-configured to keep both the random seed and temp files portably so the user doesn't need to manually adjust any of those settings.
    LANGUAGE SWITCHING - It automatically switches language with the PortableApps.com Platform. So, if you have your menu in German and download WinSCP Portable in PortableApps.com Format, when you launch WinSCP it will automatically come up in German.
    WORKING WITH PUTTY - WinSCP Portable works with PuTTY Portable without impacting any locally used PuTTY or WinSCP connections
PortableApps.com Format is the open standard for portable software. With the installers, launchers and platform, it's similar to U3 but it is open source, works with any device and is far more popular. And GPLed software can legally be packaged in PortableApps.com Format (GPLed software can not be packaged using U3's installer. The FSF has confirmed this).
I'm aware of the advantages. I just wanted to let my users know that WinSCP itself can do part of the task.
