Topic "Error after login: "Server sent command exit status 37" ?"
Hello Forum,
I do have problems after the login of a SCP-conection. Unfortunately I could not find any information about my error-message anywhere:
"(ESshFatal) Connection has been unexpectedly closed. Server sent command exit status 37"
The log-file does not give any more information to me.
Any help appreciated.
Thx
. 2007-10-13 19:23:52.250 --------------------------------------------------------------------------
. 2007-10-13 19:23:52.265 WinSCP Version 4.0.3 (Build 345) (OS 5.1.2600 Service Pack 2)
. 2007-10-13 19:23:52.265 Login time: Samstag, 13. Oktober 2007 19:23:52
. 2007-10-13 19:23:52.265 --------------------------------------------------------------------------
. 2007-10-13 19:23:52.265 Session name: ***@****
. 2007-10-13 19:23:52.265 Host name: ****(Port: ****)
. 2007-10-13 19:23:52.265 User name: **** (Password: No, Key file: Yes)
. 2007-10-13 19:23:52.265 Tunnel: No
. 2007-10-13 19:23:52.265 Transfer Protocol: SCP
. 2007-10-13 19:23:52.265 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2007-10-13 19:23:52.265 Proxy: none
. 2007-10-13 19:23:52.265 SSH protocol version: 2; Compression: No
. 2007-10-13 19:23:52.265 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2007-10-13 19:23:52.265 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2007-10-13 19:23:52.265 SSH Bugs: -,-,-,-,-,-,-,-
. 2007-10-13 19:23:52.265 SFTP Bugs: -,-,-
. 2007-10-13 19:23:52.265 Return code variable: Autodetect; Lookup user groups: Yes
. 2007-10-13 19:23:52.265 Shell: default, EOL: 0
. 2007-10-13 19:23:52.265 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2007-10-13 19:23:52.265 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2007-10-13 19:23:52.265 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2007-10-13 19:23:52.265 Cache directory changes: Yes, Permanent: Yes
. 2007-10-13 19:23:52.265 DST mode: 1
. 2007-10-13 19:23:52.328 Looking up host "****"
. 2007-10-13 19:23:52.328 Connecting to **** port ****
. 2007-10-13 19:23:52.421 Server version: SSH-2.0-OpenSSH_3.9p1
. 2007-10-13 19:23:52.421 We claim version: SSH-2.0-WinSCP_release_4.0.3
. 2007-10-13 19:23:52.421 Using SSH protocol version 2
. 2007-10-13 19:23:52.453 Doing Diffie-Hellman group exchange
. 2007-10-13 19:23:52.578 Doing Diffie-Hellman key exchange
. 2007-10-13 19:23:53.046 Host key fingerprint is:
. 2007-10-13 19:23:53.046 ssh-rsa ****
. 2007-10-13 19:23:53.046 Initialised AES-256 client->server encryption
. 2007-10-13 19:23:53.046 Initialised HMAC-SHA1 client->server MAC algorithm
. 2007-10-13 19:23:53.046 Initialised AES-256 server->client encryption
. 2007-10-13 19:23:53.046 Initialised HMAC-SHA1 server->client MAC algorithm
! 2007-10-13 19:23:53.140 Using username "****".
. 2007-10-13 19:23:53.156 Reading private key file "****"
. 2007-10-13 19:23:53.187 Offered public key
. 2007-10-13 19:23:53.312 Offer of public key accepted
! 2007-10-13 19:23:53.312 Authenticating with public key "imported-openssh-key"
. 2007-10-13 19:23:53.312 Passphrase prompt (Passphrase for key "imported-openssh-key": )
. 2007-10-13 19:24:00.390 Access granted
. 2007-10-13 19:24:00.421 Opened channel for session
. 2007-10-13 19:24:00.453 Started a shell/command
. 2007-10-13 19:24:00.453 --------------------------------------------------------------------------
. 2007-10-13 19:24:00.453 Using SCP protocol.
. 2007-10-13 19:24:00.468 Doing startup conversation with host.
. 2007-10-13 19:24:00.468 Skipping host startup message (if any).
> 2007-10-13 19:24:00.468 echo "WinSCP: this is end-of-file:0"
. 2007-10-13 19:24:00.500 Server sent command exit status 37
. 2007-10-13 19:24:00.500 All channels closed. Disconnecting
. 2007-10-13 19:24:00.500 Server closed network connection
* 2007-10-13 19:24:00.515 (ESshFatal) Connection has been unexpectedly closed. Server sent command exit status 37.
* 2007-10-13 19:24:00.515 Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
Have you checked a log file of the server?
