Topic "Server Refused Our Key...But Command line putty works."
Nonek
Hello, This is what I get when I try to connect.. I have already sent thme my public key and they have regestred it.. When I do the command line
c:\Program Files\PuTTY-0.53b\psftp" -i \path\to\keys\LED-identity.ppk sftp@206.242.19.34
It works... But when I use it in Winscp, this is what I get..
. WinSCP Version 3.1.0 (Build 165)
. Login time: Wednesday, July 23, 2003 12:42:00 PM
. Session name: dan.bartz@apollogrp.edu@206.242.19.34
. Host name: 206.242.19.34 (Port: 22)
. User name: dan.bartz@apollogrp.edu (Password: No, Key file: Yes)
. Transfer Protocol: SFTP
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: none
. Shell: default, EOL: 0
. Looking up host "206.242.19.34 "
. Connecting to 206.242.19.34 port 22
. Server version: SSH-2.0-OpenSSH_3.5p1
. We claim version: SSH-2.0-PuTTY-Local: Jul 14 2003 13:14:02
. Host key fingerprint is:
. ssh-rsa 1024 83:75:8e:cf:17:f1:f5:99:6f:b4:b7:79:67:6f:b8:8f
! Using username "dan.bartz@apollogrp.edu".
. Reading private key file "C:\Downloads\Putty\putty\LED-identity.ppk"
. Offered public key
! Server refused our key
. Server refused public key
! No supported authentication methods left to try!
. No supported authentications offered. Disconnecting
* (ESshFatal) Authentication failed.
* Authentication log (see session log for details):
* Using username "dan.bartz@apollogrp.edu".
* Server refused our key
* No supported authentication methods left to try!
* Connection has been unexpectedly closed.
I have been trying to turn on the bugs and change the authentication protocols and I'm pretty much at a loss....
Any help or direction you could give would be greatly appreciated....
Thanks...
Dan
Nonek
Heh.. I had to take out my email address as user name... I just put something in "sftp" and used pageant with my key and Voila!!!
Thanks!!!
