Topic "Default settings for stored sessions"
scam
I could not find where I can change default settings for new session. Example: I want all sessins which I created saves directories paths and uses "Executing dummy protocol commands". But I need to set it every time for each session now? Does it have such settings? Could you add it if it does not have?
Use Set defaults button on Stored sessions tab of login dialog.
Sorry but it is FAR plugin thread and I mean FAR plugin settings...
Sorry, I haven't noticed that the question was about FAR plugin. You cannot set defaults in the plugin yet. This issue has been added to tracker. Meanwhile, you can set the defaults in the application. Plugin will use them.
