Topic "overwrite confirmation always on with FTP"
petr.pavel
Hi Martin,
I have the latest WinSCP as FAR Plugin 1.6 beta.
When I connect using plain ol' FTP and try to upload a file that already exists I get "Remote file '...' already exists. Overwrite?" question no matter what I chose in Far Options / Plugin Configuration / WinSCP / Confirmations: Overwriting of files
Selecting "Never ask me again" doesn't have any effect on the question. It does turn off the Confirmation option in Plugin Configuration though.
It's just that the configuration option isn't taken into account.
It's just a minor thing, I'm glad that you incorporated FTP into WinSCP FAR Plugin so that I can enjoy Synchronised browsing even with FTP.
Thanks a heap mate.
Petr
P.S.: About option in WinSCP plugin configuration shows "Specified file info string not available".
Life is what you make it.
This is know issue (see tracker) that has been resolved in WinSCP 4.0.7. Once the plugin is updated, it will also include the fix.
petr.pavel
Hello Martin,
any chance you could update the plug-in any time soon?
I know you're doing this in your free time I would just like to "ping" this thread to express my continuing interest Smile
Thanks.
Petr
Plugin will be updated once final version of 4.1.x is released. Hopefully it will be the next one Smile
Jim_S
AFAIK I'm running the latest release (4.1.4, build 407) and have this problem only when source folders are empty.
Jim
This forum is about FAR plugin. Anyway, why do you expect overwrite confirmation if there are no source files?
Jim_S
No, I don't expect a overwrite confirmation. I choose the option for disabling that confirmation when I run WinSCP within a Explorer shell but every time when there is a empty folder to copy, I get that annoying confirmation screen.
Sorry for using the wrong forum, I've found this thread while searching for the problem I'm dealing with.
Jim
Can you post a screenshot?
Jim_S
Ok, here is a sample.
This is my starting session:
While copying an empty folder I get an error like this:
My FTP host is DriveHQ. Please let me know if you need more info.
Regards,
Jim
Sorry, that's an error message, not confirmation message. Can you post a log file?
petr.pavel
Thank you, thank you, thank you! It was a major pain for me and now it's gone. What a relief.
Thanks a bunch, Martin.
Petr
