WinSCP 4.1.2 - ignore local path value by option synchronize
scheste
Germany, 73312
I use now WinSCP 4.1.2 because the version 4.0.7 have a bug with parameter -criteria= by the synchronize option.
But the new version have new other bug :(
I use the following script for a file synchronization task.
option batch on
option synchdelete on
open PACS
option exclude "/var/data/emma/mfg/TEST DROP BOX - DO NOT USE\*"
synchronize local y:\Images\Images\PACS -criteria=size
The problem is, that winscp ignore the paramater for the local path y:\Images\Images\PACS.
But this works befor on version 4.0.7.
Regards,
Stefan
Re: WinSCP 4.1.2 - ignore local path value by option synchro
It was not a bug. The feature was simply not implemented in 4.0.7 yet.
Thanks. This issue has been added to tracker.
Meanwhile you can do:
lcd y:\Images\Images\PACS
synchronize local -criteria=size
scheste
Germany, 73312
I will test the workaround...
Thanks for your fast response!
Regards,
Stefan
