Auto-reconnect after disconnecting while transfer
Brian
Hi, is there an option to force WinSCP to auto-reconnect and resume downloading after a disconnect? The Options | Endurance | "Automatically reconnect..." options doesn't seem to work. Becuase it's on. And it keeps getting disconnected I dunno why. (That must be another problem) Is there another option I'm missing here?
-Brian
Re: Auto-reconnect after disconnecting while transfer
Can you port a complete error message you are getting on disconnect? Also what protocol are you using? SFTP/FTP/SCP?
