Topic "Connection Failed"
Becky
I'm trying to set up winSCP so I can upload my website via FTP. When I try to login all I get is 'Connection Failed'. My host name, password and username is correct.
Can you post a log file?
Smasher
I have the same problem, I use the portable version of winscp.
Where can I find the log-file?
Greetz,
Jos.
Greetz,
Jos.
I found it...see below:
. 2008-08-25 09:47:41.836 --------------------------------------------------------------------------
. 2008-08-25 09:47:41.836 WinSCP Version 4.1.6 (Build 412) (OS 5.1.2600 Service Pack 2)
. 2008-08-25 09:47:41.836 Login time: maandag 25 augustus 2008 9:47:41
. 2008-08-25 09:47:41.851 Session name: jos@83.87.225.253
. 2008-08-25 09:47:41.851 Host name: 83.87.225.253 (Port: 21)
. 2008-08-25 09:47:41.851 User name: jos (Password: No, Key file: No)
. 2008-08-25 09:47:41.851 Tunnel: No
. 2008-08-25 09:47:41.851 Transfer Protocol: FTP
. 2008-08-25 09:47:41.851 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2008-08-25 09:47:41.851 Proxy: none
. 2008-08-25 09:47:41.851 FTP: Passive: No
. 2008-08-25 09:47:41.851 Local directory: C:\Documents and Settings\jbouma\Mijn documenten, Remote directory: /public_html, Update: No, Cache: Yes
. 2008-08-25 09:47:41.851 Cache directory changes: Yes, Permanent: Yes
. 2008-08-25 09:47:41.851 DST mode: 1
. 2008-08-25 09:47:41.851 --------------------------------------------------------------------------
. 2008-08-25 09:47:41.851 Password prompt (no password provided or last login attempt failed)
. 2008-08-25 09:47:47.167 Connecting to 83.87.225.253 ...
. 2008-08-25 09:47:52.389 Connection failed.
* 2008-08-25 09:47:52.389 (ESshFatal) Connection failed.
* 2008-08-25 09:47:52.389 Connection failed.
Please check some hints.
