Topic "window title: add servername in front"
FredJ
Currently a winscp window title looks like this:
"/path/path/path/path - account@servername - WinSCP"
Would be cool, to have the window title like this:
"servername - /path/path/path/path - account@server - WinSCP"
Reason for request:
In the windows task bar you can see the first ~10 characters of a window title. If you have several winscp windows open, it's sometimes difficult to select the correct window in the task bar.
Usually the first 10 letters of a servers path do not help distinguishing several open winscp sessions.
BTW, the behavior you are seeing is not default, so you had to set it like that... Wink
JRAN1
I would like to customize the Window Title when I use WinSCP via command line. I have numerous scripts running on the same machine. When a window gets left behind, it's difficult to determine which script needs editing. Thanks, James
You can setup a specific stored session for each of your script.
Still it would be nice to specify title on the command line. I have lots of hosts accessed via on demand generated SSH tunnels. It will show me user@localhost - not the name of the server.
OK, this request is tracked here:
http://winscp.net/tracker/show_bug.cgi?id=1183
