I want F10 back!
E. Dronkert
I want F10 back!
Hi there! In the newest version (3.2.1) you disabled the F10 key for disconnect (& exit). Now one has to use Shift-Ctrl-D en click Close... Can you please bring back the F10 shortcut? Thanks a lot.
Cheers,
Ewoud
Re: I want F10 back!
I hope you understand that the button is disabled by mistake. If it was by purpose, I would remove it at all :-) In next release it will be fixed. Anyway, you may use standard Windows shortcut Alt-F4 to close the application.
E.
OK, but that's still 2 keys :wink: Thanks for your work, looking forward to the next release.
