Topic "Problem with SFTP transfer"
Boby
This problem has ocuured since months but I wanted to be sure it came from WinSCP before posting. Here it is.
I connect regularly to the server at work (where they allow only SFTP connections, not FTP) from home in order to transfer files .
For approximately one year, using the successive latest version of WinSCP, I have been experiencing systematic and recursive disconnection when tranferring files. I need to reconnect every 15 seconds to achieve the transfer.
I have first thought it was a server issue but after inquiry it appears it was not.
I then tried other file transfer softwares enabling SFTP connections (essentially FireFTP and Fillezilla) with which I have had no problem at all: the transfer is fine and fast (no disconnections).
Therfore, it may be possible that this is a WinSCP issue.
I am ready to furnsih other details to help you if you need.
Yours,
Boby
Please post a piece of log file showing the disconnect. Or at least a complete error message.
Boby
OK Thanks.
I just sent you a logfile by mail.
Boby
Boby
Looking again at the forum, it may be possible that the issue I am experiencing is the same as the one described in Topic "Why is WinSCP so slow?"
For information, I use WinSCP 4.1.6 on Windows XP SP3.
Boby
