Topic "99% file drop"
Luigi
Hello, I am having a problem when I try to put files to my ftp server. It gets up to 99% then for some reason the connection drops and it gives me this erroe message:
"Timeout dected. Copying files to remote side failed. Opening BINARY mode dataconnection for "file name here"".
It happens with every file that I try to put on, I would like to know if anyone has an solution to this.
What is your FTP server?
mrhuge
Hi, Martin!
I have the same issue on one of my ftp servers.
When I download large files from server (for example more 60 MB), when download comes to 99%, winscp hangs then shows this:
Lost connection.
Timeout detected.
Copying files from remote side failed.
Opening BINARY mode data connection for file.zip (77644380 bytes)
And then winscp reconnects by itself and finishes download. File size on hard drive seems to have the same size as on server. Buy I don't know for sure if downloading was completed or not.
Is it safe to use site backup archives, which are downloaded through such reconnect? Is such download finished?
Here's session log:
WinSCP Version 4.3.5 (Build 1463) (OS 5.1.2600 Service Pack 3)
Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
Local account: ANDREY\Admin
Login time: 24 Ноябрь 2011 г. 16:41:36
Session name: v002261@v2.fastvps.ru (Stored session)
Host name: v2.fastvps.ru (Port: 21)
User name: v002261 (Password: Yes, Key file: No)
Tunnel: No
Transfer Protocol: FTP
Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
Proxy: none
FTP: FTPS: None; Passive: Yes [Force IP: No]
Local directory: default, Remote directory: home, Update: No, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
DST mode: 1
Connecting to v2.fastvps.ru ...
Connected with v2.fastvps.ru. Waiting for welcome message...
220 213.239.201.135 FTP server ready
USER v002261
331 Password required for v002261
PASS **********
230 User v002261 logged in
SYST
215 UNIX Type: L8
FEAT
211-Features:
 LANG en
 MDTM
 UTF8
 REST STREAM
 SIZE
211 End
OPTS UTF8 ON
200 UTF8 set to on
Connected
Using FTP protocol.
Doing startup conversation with host.
PWD
257 "/" is the current directory
Getting current directory name.
Retrieving directory listing...
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (213,239,201,135,93,95).
LIST -a
150 Opening ASCII mode data connection for file list
226 Transfer complete
Directory listing successful
Reading symlink "public_html".
Reading symlink "tmp".
Startup conversation with host finished.
Cached directory change via "www" to "/www".
CWD /www/
250 CWD command successful
PWD
257 "/www" is the current directory
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (213,239,201,135,228,136).
LIST -a
Cached directory change via "muzalliance.ru" to "/www/muzalliance.ru".
CWD /www/muzalliance.ru/
PWD
257 "/www/muzalliance.ru" is the current directory
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (213,239,201,135,96,109).
LIST -a
Cached directory change via "administrator" to "/www/muzalliance.ru/administrator".
CWD /www/muzalliance.ru/administrator/
PWD
257 "/www/muzalliance.ru/administrator" is the current directory
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (213,239,201,135,135,63).
LIST -a
Cached directory change via "components" to "/www/muzalliance.ru/administrator/components".
CWD /www/muzalliance.ru/administrator/components/
PWD
257 "/www/muzalliance.ru/administrator/components" is the current directory
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (213,239,201,135,138,46).
LIST -a
Cached directory change via "com_akeeba" to "/www/muzalliance.ru/administrator/components/com_akeeba".
CWD /www/muzalliance.ru/administrator/components/com_akeeba/
PWD
257 "/www/muzalliance.ru/administrator/components/com_akeeba" is the current directory
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (213,239,201,135,72,161).
LIST -a
Cached directory change via "backup" to "/www/muzalliance.ru/administrator/components/com_akeeba/backup".
CWD /www/muzalliance.ru/administrator/components/com_akeeba/backup/
PWD
257 "/www/muzalliance.ru/administrator/components/com_akeeba/backup" is the current directory
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (213,239,201,135,176,206).
LIST -a
File: "/www/muzalliance.ru/administrator/components/com_akeeba/backup/site-muzalliance.ru-20111124-115747.zip"
Copying "/www/muzalliance.ru/administrator/components/com_akeeba/backup/site-muzalliance.ru-20111124-115747.zip" to local directory started.
Binary transfer mode selected.
Starting download of /www/muzalliance.ru/administrator/components/com_akeeba/backup/site-muzalliance.ru-20111124-115747.zip
TYPE I
200 Type set to I
PASV
227 Entering Passive Mode (213,239,201,135,177,156).
RETR site-muzalliance.ru-20111124-115747.zip
150 Opening BINARY mode data connection for site-muzalliance.ru-20111124-115747.zip (77644380 bytes)
Timeout detected.
Connection was lost, asking what to do.
Asking user:
Lost connection. ("Timeout detected.","Copying files from remote side failed.","Opening BINARY mode data connection for site-muzalliance.ru-20111124-115747.zip (77644380 bytes)")
USER v002261
PASS **********
SYST
215 UNIX Type: L8
FEAT
211-Features:
 LANG en
 MDTM
 UTF8
 REST STREAM
 SIZE
211 End
OPTS UTF8 ON
200 UTF8 set to on
Connected
PWD
Changing directory to "/www/muzalliance.ru/administrator/components/com_akeeba/backup".
PWD
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (213,239,201,135,178,141).
LIST -a
TYPE I
200 Type set to I
PASV
227 Entering Passive Mode (213,239,201,135,105,160).
REST 77644380
350 Restarting at 77644380. Send STORE or RETRIEVE to initiate transfer
Download successful
-Andrey
Any chance of having a test account on your server?
Also have you tried increasing server response timeout?
mrhuge
Hi, Martin.
You mean me to give you server, login and password for ftp on my server? Yes I can send it in private.
Honestly, I don't know where to change this server response.
mrhuge
Sent you account info to your e-mail from your profile.
mrhuge
Martin had no problems downloading my big file, but I still have. Maybe it's because of my russian internet provider or wifi router. My hosting-provider and winscp developer believe it is safe to use such dropped/reconnected files, so I will use them.
Thanks Martin for his great program.
