Topic "call command fails"
dje2006dje
hi,
It seems that the call command doesn t run inside the command line with automation script (winscp.exe /console etc ...) .
I suppose due to script line command only uses to transfert files.
But inside Winscp "terminal/console" tool, all call commands run fine.
Is it possible to start command line without filetransfert support ? Or is it possible to run call command (ex call bdf ) with "winscp.exe /console" ?
You can run call from command line. What problem do you have exactly?
