Topic "Password box in 3.3"
Bob Isaac
For some reason, a dialogue box comes up and asks for a password when starting v3.3, even though the password is saved. Even if I put nothing in the box and click OK it will still connect. Any ideas?
Bob
I'll look at this.
mattgick
do you happen to have an @ in you password? same problem here Wink using FreeBSD...
for some reason I don't have this problem in linux, maybe because that one is running the latest version of openssh... might by BSD related though...
prikryl: I posted a topic on this a while ago... just to let you know, the problem seems to not exist in linux with openssh 3.7.1_p2
and indeed bob, if you click OK without reentering the password, authentication still succeeds... weird Wink
mattgick
by the way, the problem also seems to exist in previous versions of winscp
I've had a same problem few days with OpenSSH server on Sourceforge (and only with this server). I was not able to find a cause. Several days ago, the problem disapeared and it never happened since. I was not able to find out, if there were any upgrades at the time.
Chris from NJ (USA)
I'm new with using WinSCP, but found myself reading the forums because I too have the same problem.
Under SSH Authentication, if I uncheck 'Attept "keyboard-interactive" authentication (SSH2)' -- I think it fixes it.
Try it and see.
Chris
What is your server?
Chris from NJ (USA)
ssh on linux
Mike
I admin Chris' server, to be specific the server is OpenSSH_3.7.1 on Linux.
ssh on linux
Thanks for the info.
