Topic "directory focus problem (commander)"
petrma
Hi, by using commander interface with keyboard, I have some trouble with directory focus. If you are used to file commanders, you will probably know instantly what behaviour I am missing.
Each time after I enter the directory and go back (enter or click on ".."), program focuses on ".." in parent directory, not on parent directory itself. Example:
Directory "food"
fruits
vegetables
cakes
click on "cakes"
click on ".." in "cakes"
--> focus is on ".." not on "cakes"
this could be fine on 3 items per directory, as in this example, but how about tens of directories, or hundreds? If you are traversing the directories, or entered some directory by mistake, you have to find it again, not speaking about loosing the eye focus all the time.
I have tried with Ctrl-Left, different configuration checkboxes, but nothing happened. Maybe there is some configuration option that I am missing?
Petr (eventual email <removed>)
WinSCP does that. I'll send you a debug version soon to trace a reason why it is not working for you.
petrma
Problem resolved (should be fixed in versions > 4.1.Cool
Big thanks to the author!
This bug has been added to tracker.
