Topic "Selectable settings location"
ByteHeaven
It would be really nice, if you could on settings select _where_ settings ini is. Personally I have all the settings of software under different drive than system. Thus if system breaks I can just re-install Windows and do not have to think what I need to backup first. Now you loose WinSCP settins and sites on format..
Use /ini command-line parameters.
