Topic "Winscp Portable problem - help please"
habeeeb
Hi all,
I'm using Winscp portable (or the non-installable one) by running it directly from an external HD.
What I need is to have an external editor (Notepad++ for example) to run when I double-click any text file for example.
I can have it working but only with an exact path to the notepad++ executable which is also on the HD.
Now this means every time I change the PC a drive letter is assigned to the HD, so I have to change the settings of the external editor ever time.
Question: Do relative paths work when setting up an external editor from winscp and if so, how do I know the directory I actually start from.
Relative paths are relative to WinSCP startup directory.
Also see documentation regarding WinSCP portable use.
habeeeb
Fixed.
Apparently I didn't have the startup directory properly set up.
Thanks.
