Topic "Where is the WINSCP Temporary File?? I have lost important d"
SparxDesign
Hey people,
I love WINSP! It's the greatest FTP program. But I have a couple of problems.
When I select files from remote server and drag them to desktop or something, it MOVES them from server, instead of copying. how can I make it so it automatically copys instead of moving it? (Like WS_FTP).
Also to make matter worse, sometimes it doesn't actually move the file, and I have lost it from the server and no where to be seen on local drive. I also can't find the TEMPORARY DIRECOTRY where WINSCP saves the files to, it says the default temp directory in settings, but where can I find this???
Thanks - much appreciated!
Sheldon Kirk
kyboren
Not sure on the second part, but did you try pressing <Ctrl> while dragging to copy instead of move?
Check your TEMP or TMP environment variable. By default it points to:
C:\Documents and Settings\<username>\Local Settings\Temp
