Topic "Backing up cydia"
sykotic_nubcake
Well let me start by saying im pretty much 30 minutes new to open ssh. i've tried to stay away from it because it always looked like a very hokey and difficult way of doing things. And i was completely wrong. im decent with computers, so this basically looks like a very very simple registry/hard drive and adding removing or replacing files seems as easy as can be, i've already browsed through most everything and found most of what i wanted. (im sending my ipod in to apple for some warranty work and want to back up ALL my cydia stuff)
well i found all my cydia applications and copied them for later addition and i found all my themes for winterboard, copied them as well. And i also copied the application cydia because i saw that it help all the sources etc that i had to put in at one point to save myself some time. however, i cant find many things like the utilities from cydia such as "imobilecinema" or "five dock icons" is there a specific place to find this stuff or if i just completely replace the cydia app with the one i already backed up will it automaticaaly have this stuff included?
or is there a completely easier way to completely back up all cydia stuff that i currently have?
thank you for all your support. i will definitely be getting to know opessh a lot more for its speed and ease of use. Mr. Green Mr. Green
Please read FAQ.
sykotic_nubcake
typical forum admin. instead of just leaving the post to be answered you try to treat me like a retard and tell me its right in front of my face. its not in the faq. i asked a specific question in which your faq or the related site could not answer. so shut up
sykotic_nubcake wrote:
i asked a specific question in which your faq ... could not answer.
Correct. That's what the FAQ say.
