shitf + F6 does not work like in far
thcom
Hi, i dont know if it is a bug, but when i want o rename a single file in far (for example on disk D:) i get dialog with this single file name and i can edit thid, but in winscp plugin i get complete file path with *.* on end
i know that functin on shift + F6 is named moveTo and in far it is rename, but this is very uncomfortable for me
thanx for any advice
Re: shitf + F6 does not work like in far
I cannot check right now, but I believe that WinSCP plugin follows the FAR navigator (FTP plugin) convention.
Anyway, you can use Shift+Alt+F6 to get name only.
thcom
in ftp pluging works shift+F6 not like in WinSCp plugin
but your tip with shift+alt+f6 works fine for me, THANKS !
