Topic "How to synchronize"
Leon
I try synchronize my folder with FTP-server by using script:
option batch on
option confirm on
open ftp://Leonid.romanov:Brass8*@10.11.251.2:21
synchronize local d:\rom\regina \ -delete -criteria="Modification time"
close
But winscp419.exe does not copied newest files with the same names. Why? How can I tell them to do that? And haw can I use "-criteria" for this?
Thank
Path to remote directory should be / not \.
Also it is -criteria=time, there's no "modification time" option.
Leon
Thanks!
As about "\" - it works fine (in WXP). But WHAT and HOW must I write in "-criteria=" ?
I'd not found the answer for this question in DOC and FAQ Sad(
To my previous post: synchronization works OK,- my mistake took place becase FAR-manager shows some data-time values with error.
OK, so are you having any problems now? If you do, please state clearly what they are.
