Topic "Windows Vista sidebar gadget"
Daanoz
Hey people,
This ain't really a feature request, but i didn't know where to put it else... anyway, i use WinSCP a lot, along side with PuttY. Now there is a PuttYPal which makes it pretty easy to connect to the servers with putty.
When you are used to the functionality it works really handy, therefor i created WinSCPPal, which does exactly the same, but for winscp!
You can get it here: http://vista.gallery.microsoft.com/liveItemDetail.aspx?li=f66b9416-886f-4789-a1da-1c3742294ba8&bt=1&pl=1
Cheers
Comments are welcome
Thanks for sharing this!
Any idea why WinSCPPal sessions are not showing up?
duderino
Hi Daanoz
WinSCPpal ist a really great toot. Thanks for making it.
I have a little problem. When i click the connection in the sidebar list i get a timeout. But the it works when i click the little symbol in the lower left corner and then choose the connection.
what could be the reason?
duderino
What is "sidebar list" and "little symbol in the lower left". Screenshot may help.
duderino
Hi Prikryl
I admire the work you are doing for creating WinSCP, it's a great tool.
So here is a screenshot of the sidebar widget. In the big red square you see the list of all the connections configured in WinSCP. When I click one of those connections I get a timeout.
In the little red square is the symbol or icon that opens WinSCP in a new window. When I choose a connection from there it works fine.
thanks for your help.
duderino
duderino
and here comes the image....
Description: sidebar winscppal
OK. We have nothing to do that gadget. Please contact it's author.
Though my guess is that it reads session details from registry, while you may be actually using an INI file to store the configuration.
