Topic "FTP error: An established connection was aborted..."
ace
I'm trying to use WinSCP to FTP, and am getting this error:
An established connection was aborted by the software in your host machine.
Connection failed.
I've selected passive mode. I've added WinSCP to my firewall exceptions.
I'm running WinSCP Version 4.1.9 (Build 416) with Windows XP SP2.
I can access this FTP site with another FTP client, but ideally, I would be able to use WinSCP.
Any other things I should be trying?
Log of transaction:
. 2009-06-03 15:35:15.217 --------------------------------------------------------------------------
. 2009-06-03 15:35:15.217 WinSCP Version 4.1.9 (Build 416) (OS 5.1.2600 Service Pack 2)
. 2009-06-03 15:35:15.217 Login time: Wednesday, June 03, 2009 3:35:15 PM
. 2009-06-03 15:35:15.217 Session name: cnetmedia-ht-adsops@cnet-3.ocs.llnw.net
. 2009-06-03 15:35:15.217 Host name: cnet-3.ocs.llnw.net (Port: 21)
. 2009-06-03 15:35:15.217 User name: cnetmedia-ht-adsops (Password: Yes, Key file: No)
. 2009-06-03 15:35:15.217 Tunnel: No
. 2009-06-03 15:35:15.217 Transfer Protocol: FTP
. 2009-06-03 15:35:15.217 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2009-06-03 15:35:15.217 Proxy: none
. 2009-06-03 15:35:15.217 FTP: Passive: Yes
. 2009-06-03 15:35:15.217 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-06-03 15:35:15.217 Cache directory changes: Yes, Permanent: Yes
. 2009-06-03 15:35:15.217 DST mode: 1
. 2009-06-03 15:35:15.277 Connecting to cnet-3.ocs.llnw.net ...
. 2009-06-03 15:35:15.277 An established connection was aborted by the software in your host machine.
. 2009-06-03 15:35:15.277 Connection failed.
. 2009-06-03 15:35:15.277 Got reply 1004 to the command 1
* 2009-06-03 15:35:15.287 (ESshFatal) Connection failed.
* 2009-06-03 15:35:15.287 An established connection was aborted by the software in your host machine.
* 2009-06-03 15:35:15.287 Connection failed.
Can you post a log file from the other client?
From SmartFTP 3.0.1027.0 (unlicensed version)
[11:01:40] Resolving host name "cnet-3.ocs.llnw.net"
[11:01:41] Connecting to 208.111.191.217 Port: 21
[11:01:41] Connected to cnet-3.ocs.llnw.net.
[11:01:41] 220 ProFTPD 1.3.1 Server ready.
[11:01:41] USER cnetmedia-ht-adsops
[11:01:41] 331 Password required for cnetmedia-ht-adsops
[11:01:41] PASS (hidden)
[11:01:41] 230 User cnetmedia-ht-adsops logged in
[11:01:41] SYST
[11:01:42] 215 UNIX Type: L8
[11:01:42] Detected Server Type: UNIX
[11:01:42] RTT: 92.830 ms
[11:01:42] FEAT
[11:01:42] 211-Features:
[11:01:42] MDTM
[11:01:42] REST STREAM
[11:01:42] SIZE
[11:01:42] 211 End
[11:01:42] PWD
[11:01:42] 257 "/" is the current directory
[11:02:13] NOOP
[11:02:13] 200 NOOP command successful
That definitely looks like firewall issue. I would try to connect using IP address still, though I doubt it helps.
