Timestamp not working properly when DST is in effect?
I am transferring a file to a remote server via and the timestamp for the file on the server is off by 1 hour. Both systems are set for (GMT-05:00) Eastern Time (US & Canada) and "Automatically adjust clock for daylight saving changes" is checked.
On the local system the file shows as having a timestamp of Jun 4, 2009, 3:09pm. The remote system shows the same date with a time of 2:09pm
If I set the local time zone to (GMT) Greenich Mean Time, the timestamp shown in explorer on the local machine is 7:09pm. The XML log for the transfer shows the following:
<touch>
<filename value="/fromRemote/backup.db3" />
<modification value="2009-06-04T18:09:27.000Z" />
<result success="true" />
</touch>
Shouldn't the value be ="2009-06-04T19:09:27.000Z"?
Files that have timestamps where DST is not in effect (e.g. Feb 4, 2008, 5:28pm) appear to have the correct timestamp on the remote system.
I am currently using WinSCP 4.2.1 (build 428), but this happened for 4.1.8 and 4.1.9 as well.
The remote machine is running freeFTPd version 1.0.11
byngl at users dot sourceforge dot net
I forgot to mention that both systems are running Windows XP. The local one Home (SP3), the remote Pro (SP3). Both have the latest updates from Microsoft applied.
Re: Timestamp not working properly when DST is in effect?
Please read documentation:
<link removed by admin as the functionality is deprecated>
If that does not help, come back.
