Topic "passwd on the terminal"
ruglen
hi!
I have a problem with the passwd command on WinSCP 3.3.0
I open the terminal (Crt+T)
type "passwd" and have the following message:
Host hasn't answerer for 15 seconds.
Wait for another 15 seconds? Pressing abort button will close session.
Waring: Aborting this operation will close connection!
[Abort] [Retry]
I have pressed Retry a lot of times and there is always the same message.
on another host, i got this message:
Command "passwd"
failed with return code 3 and error message
Unexpected failure. Password file/table unchanged..
[OK]
What can i do to solve these problems?
thanks in advance!
You may NOT use commands that require input from user in Terminal window.
ruglen
ok. thanks for your reply!
May I ask why this is?
For two reasons:
- I have not implemented terminal input
- Most of programs require TTY (interactive terminal) to process user input. WinSCP cannot have TTY as it is incompatible with SCP/SFTP.
prikryl wrote:
For two reasons:
Right now Im using two ssh programs for a project. I like WinSCP because I can edit files directly off the server using Textpad. But since I can't use a terminal in the usual way, I use Tunnelier for its terminal.
Personally Id prefer to just use WinSCP. Is there a way to have a terminal window integrated with it, possibly using another more basic terminal than tunnelier?
TIA
That would mean to establish new terminal connection in addition to the SCP/SFTP one. The same effect can be achieved using "Open in Putty" command (if you have Putty SSH terminal installed).
BV
Hi, I too type passwd in terminal ->
[Abort] [Retry]
But my password changed and can't access!
BV
version is 416
