Topic "Error Lost connection"
Sim
╔════════════════════════════ Error ════════════════════════════╗
║ Lost connection.                                              ║
║ Disconnected from server                                      ║
║ No transfer timeout (300 seconds): closing control connection ║
║                              Ok                               ║
I think WinSCP must auto reconnect to server if any connection error occured.
Or it must nothing to do (no any error messages occured, and do not switch panel to HDD) and reconnect when user do any action that need this connection.
Can You change WinSCP Far plugin for don't show this message and don't close panel?
Log file:
. 2009-06-30 05:54:13.852 --------------------------------------------------------------------------
. 2009-06-30 05:54:13.868 WinSCP Version 1.6.2 (Build 151) (OS 5.1.2600 Service Pack 3)
. 2009-06-30 05:54:13.868 Login time: 30 Июнь 2009 г. 5:54:13
. 2009-06-30 05:54:13.868 --------------------------------------------------------------------------
. 2009-06-30 05:54:13.868 Session name: xxx.com
. 2009-06-30 05:54:13.868 Host name: xxx.xxx.xxx.xxx (Port: 21)
. 2009-06-30 05:54:13.868 User name: xxx (Password: Yes, Key file: No)
. 2009-06-30 05:54:13.868 Tunnel: No
. 2009-06-30 05:54:13.868 Transfer Protocol: FTP
. 2009-06-30 05:54:13.868 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2009-06-30 05:54:13.868 Proxy: none
. 2009-06-30 05:54:13.868 FTP: Passive: No
. 2009-06-30 05:54:13.868 Local directory: default, Remote directory: /home/xxx, Update: Yes, Cache: Yes
. 2009-06-30 05:54:13.868 Cache directory changes: Yes, Permanent: Yes
. 2009-06-30 05:54:13.868 DST mode: 1
. 2009-06-30 05:54:13.883 Connecting to xxx.xxx.xxx.xxx ...
. 2009-06-30 05:54:13.930 Connected with xxx.xxx.xxx.xxx. Waiting for welcome message...
< 2009-06-30 05:54:14.008 220 ProFTPD 1.3.1 Server (ProFTPD Default Installation) [xxx.xxx.xxx.xxx]
> 2009-06-30 05:54:14.008 USER xxx
< 2009-06-30 05:54:14.071 331 Password required for xxx
> 2009-06-30 05:54:14.071 PASS **********
< 2009-06-30 05:54:14.196 230 User xxx logged in
> 2009-06-30 05:54:14.196 SYST
< 2009-06-30 05:54:14.258 215 UNIX Type: L8
> 2009-06-30 05:54:14.258 FEAT
< 2009-06-30 05:54:14.321 211-Features:
< 2009-06-30 05:54:14.321  MDTM
< 2009-06-30 05:54:14.321  REST STREAM
< 2009-06-30 05:54:14.321  SIZE
< 2009-06-30 05:54:14.539 211 End
. 2009-06-30 05:54:14.539 Connected
. 2009-06-30 05:54:14.539 Got reply 1 to the command 1
. 2009-06-30 05:54:14.539 --------------------------------------------------------------------------
. 2009-06-30 05:54:14.539 Using FTP protocol.
. 2009-06-30 05:54:14.539 Doing startup conversation with host.
> 2009-06-30 05:54:14.555 PWD
< 2009-06-30 05:54:14.602 257 "/home/xxx" is the current directory
. 2009-06-30 05:54:14.602 Got reply 1 to the command 16
. 2009-06-30 05:54:14.602 Changing directory to "/home/xxx".
> 2009-06-30 05:54:14.602 CWD /home/xxx
< 2009-06-30 05:54:14.664 250 CWD command successful
. 2009-06-30 05:54:14.664 Got reply 1 to the command 16
. 2009-06-30 05:54:14.664 Getting current directory name.
> 2009-06-30 05:54:14.664 PWD
< 2009-06-30 05:54:14.727 257 "/home/xxx" is the current directory
. 2009-06-30 05:54:14.727 Got reply 1 to the command 16
. 2009-06-30 05:54:14.743 Retrieving directory listing...
> 2009-06-30 05:54:14.743 TYPE A
< 2009-06-30 05:54:14.789 200 Type set to A
> 2009-06-30 05:54:14.805 PORT 89,187,36,2,6,229
< 2009-06-30 05:54:14.852 200 PORT command successful
> 2009-06-30 05:54:14.852 LIST -a
< 2009-06-30 05:54:14.977 150 Opening ASCII mode data connection for file list
. 2009-06-30 05:54:15.086 drwxr-xr-x  19 xxx    xxx        4096 Jun 26 03:03 .
. 2009-06-30 05:54:15.086 drwxr-xr-x  12 root     root         4096 May 25 16:19 ..
. 2009-06-30 05:54:15.086 -rw-rw-rw-   1 xxx    xxx         390 Jun 29 20:02 .htaccess
. 2009-06-30 05:54:15.086 -rw-r--r--   1 xxx    xxx        1269 Feb 16 01:50 101.php
. 2009-06-30 05:54:15.086 -rw-r--r--   1 xxx    xxx        3595 Feb 21 12:50 102.php
. 2009-06-30 05:54:15.086 -rw-r--r--   1 xxx    xxx        4819 Jun  1 01:40 103.php
. 2009-06-30 05:54:15.086 -rw-r--r--   1 xxx    xxx        4449 May  8 03:22 104.php
. 2009-06-30 05:54:15.086 -rw-r--r--   1 xxx    xxx        6633 May 30 08:51 106.php
. 2009-06-30 05:54:15.086 -rw-r--r--   1 xxx    xxx        3991 Feb 27 05:02 107.php
. 2009-06-30 05:54:15.086 -rw-r--r--   1 xxx    xxx         475 Mar  2 13:18 108.php
. 2009-06-30 05:54:15.086 -rw-r--r--   1 xxx    xxx         291 May 13 02:31 109.php
< 2009-06-30 05:54:15.149 226 Transfer complete
. 2009-06-30 05:54:15.149 Directory listing successful
. 2009-06-30 05:54:15.149 Got reply 1 to the command 2
. 2009-06-30 05:54:15.149 Startup conversation with host finished.
. 2009-06-30 05:54:17.289 Session upkeep
. 2009-06-30 05:54:17.430 Session upkeep
. 2009-06-30 05:54:17.555 Session upkeep
. 2009-06-30 05:54:17.680 Session upkeep
. 2009-06-30 05:54:17.805 Session upkeep
. 2009-06-30 05:54:17.930 Session upkeep
. 2009-06-30 05:54:18.071 Session upkeep
. 2009-06-30 05:54:18.196 Session upkeep
. 2009-06-30 05:54:18.321 Session upkeep
. 2009-06-30 05:54:18.446 Session upkeep
. 2009-06-30 05:54:18.571 Session upkeep
. 2009-06-30 05:54:18.711 Session upkeep
. 2009-06-30 05:54:18.836 Session upkeep
. 2009-06-30 05:54:18.977 Session upkeep
. 2009-06-30 05:54:19.102 Session upkeep
. 2009-06-30 05:54:19.227 Session upkeep
. 2009-06-30 05:54:19.352 Session upkeep
. 2009-06-30 05:54:19.477 Session upkeep
. 2009-06-30 05:54:19.602 Session upkeep
. 2009-06-30 05:54:19.727 Session upkeep
. 2009-06-30 05:54:19.852 Session upkeep
. 2009-06-30 05:54:19.977 Session upkeep
. 2009-06-30 05:54:20.102 Session upkeep
. 2009-06-30 05:54:20.227 Session upkeep
. 2009-06-30 05:54:20.352 Session upkeep
. 2009-06-30 05:54:20.493 Session upkeep
. 2009-06-30 05:54:20.618 Session upkeep
. 2009-06-30 05:54:20.743 Session upkeep
. 2009-06-30 05:54:20.868 Session upkeep
. 2009-06-30 05:54:20.993 Session upkeep
. 2009-06-30 05:54:21.118 Session upkeep
. 2009-06-30 05:54:21.258 Session upkeep
. 2009-06-30 05:54:21.383 Session upkeep
. 2009-06-30 05:54:21.508 Session upkeep
. 2009-06-30 05:54:21.633 Session upkeep
. 2009-06-30 05:54:21.758 Session upkeep
. 2009-06-30 05:54:21.883 Session upkeep
. 2009-06-30 05:54:22.008 Session upkeep
. 2009-06-30 05:54:22.149 Session upkeep
. 2009-06-30 05:54:22.274 Session upkeep
. 2009-06-30 05:54:22.399 Session upkeep
. 2009-06-30 05:54:22.524 Session upkeep
. 2009-06-30 05:54:22.649 Session upkeep
. 2009-06-30 05:54:22.790 Session upkeep
. 2009-06-30 05:54:22.915 Session upkeep
. 2009-06-30 05:54:23.040 Session upkeep
. 2009-06-30 05:54:23.180 Session upkeep
. 2009-06-30 05:54:23.305 Session upkeep
. 2009-06-30 05:54:23.430 Session upkeep
. 2009-06-30 05:54:23.555 Session upkeep
. 2009-06-30 05:54:23.696 Session upkeep
. 2009-06-30 05:54:23.821 Session upkeep
. 2009-06-30 05:54:23.946 Session upkeep
. 2009-06-30 05:54:24.071 Session upkeep
. 2009-06-30 05:54:24.211 Session upkeep
. 2009-06-30 05:54:24.336 Session upkeep
. 2009-06-30 05:54:24.461 Session upkeep
. 2009-06-30 05:54:24.586 Session upkeep
. 2009-06-30 05:54:24.711 Session upkeep
. 2009-06-30 05:54:24.836 Session upkeep
. 2009-06-30 05:54:24.961 Session upkeep
. 2009-06-30 05:54:25.102 Session upkeep
. 2009-06-30 05:54:25.227 Session upkeep
. 2009-06-30 05:54:25.352 Session upkeep
. 2009-06-30 05:54:25.477 Session upkeep
. 2009-06-30 05:54:25.618 Session upkeep
. 2009-06-30 05:54:25.743 Session upkeep
. 2009-06-30 05:54:25.868 Session upkeep
. 2009-06-30 05:54:25.993 Session upkeep
. 2009-06-30 05:54:26.118 Session upkeep
. 2009-06-30 05:54:26.243 Session upkeep
. 2009-06-30 05:54:26.383 Session upkeep
. 2009-06-30 05:54:26.508 Session upkeep
. 2009-06-30 05:54:26.633 Session upkeep
. 2009-06-30 05:54:26.758 Session upkeep
. 2009-06-30 05:54:26.883 Session upkeep
. 2009-06-30 05:54:27.008 Session upkeep
. 2009-06-30 05:54:27.133 Session upkeep
. 2009-06-30 05:54:27.258 Session upkeep
. 2009-06-30 05:54:27.383 Session upkeep
. 2009-06-30 05:54:27.508 Session upkeep
. 2009-06-30 05:54:27.649 Session upkeep
. 2009-06-30 05:54:27.774 Session upkeep
. 2009-06-30 05:54:27.899 Session upkeep
. 2009-06-30 05:54:28.024 Session upkeep
. 2009-06-30 05:54:28.149 Session upkeep
. 2009-06-30 05:54:28.274 Session upkeep
. 2009-06-30 05:54:28.399 Session upkeep
. 2009-06-30 05:54:28.540 Session upkeep
. 2009-06-30 05:54:28.665 Session upkeep
. 2009-06-30 05:54:28.790 Session upkeep
. 2009-06-30 05:54:28.915 Session upkeep
. 2009-06-30 05:54:29.040 Session upkeep
. 2009-06-30 05:54:29.165 Session upkeep
. 2009-06-30 05:54:29.305 Session upkeep
. 2009-06-30 05:54:29.430 Session upkeep
. 2009-06-30 05:54:29.555 Session upkeep
. 2009-06-30 05:54:29.680 Session upkeep
. 2009-06-30 05:54:29.821 Session upkeep
. 2009-06-30 05:54:29.946 Session upkeep
. 2009-06-30 05:54:30.071 Session upkeep
. 2009-06-30 05:54:31.087 Session upkeep
. 2009-06-30 05:54:31.212 Session upkeep
. 2009-06-30 05:54:31.352 Session upkeep
. 2009-06-30 05:54:32.352 Session upkeep
. 2009-06-30 05:54:32.477 Session upkeep
. 2009-06-30 05:54:32.618 Session upkeep
. 2009-06-30 05:54:32.743 Session upkeep
. 2009-06-30 05:54:32.868 Session upkeep
. 2009-06-30 05:54:40.462 Session upkeep
. 2009-06-30 06:07:54.894 Session upkeep
> 2009-06-30 06:07:54.894 PWD
< 2009-06-30 06:07:54.894 257 "/home/xxx" is the current directory
> 2009-06-30 06:07:54.894 TYPE I
< 2009-06-30 06:07:54.894 200 Type set to I
> 2009-06-30 06:07:54.894 REST 0
< 2009-06-30 06:07:54.894 350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer
> 2009-06-30 06:07:54.894 TYPE A
< 2009-06-30 06:07:54.894 200 Type set to A
< 2009-06-30 06:07:54.894 421 No transfer timeout (300 seconds): closing control connection
. 2009-06-30 06:07:54.894 Disconnected from server
. 2009-06-30 06:07:54.894 Got reply 1000 to the command 0
* 2009-06-30 06:07:54.894 (ESshFatal) Lost connection.
* 2009-06-30 06:07:54.894 Disconnected from server
* 2009-06-30 06:07:54.894 No transfer timeout (300 seconds): closing control connection
OK, maybe in the next version.
Sim
When you plan to release new version of Far plugin?
Sorry, I have no plans for this atm.
