Topic "wrong looking log-file"
Mindy
hi there!
my problem: i want to download and remove (get -delete) some files from a sftp server. ok so on that works very fine.
my problem is, that my logs are looking very unreadable. i another post here in the forum i saw an log, which would satisfy me much.
http://winscp.net/forum/viewtopic.php?t=6665&highlight=xml
i'm starting the winscp session in a bat file with
WinSCP.com /console /script=scriptfile.txt /log=logfile.txt
my scriptfile is the following:
_____________________
option batch on
open user:pw@host
cd directory
get -delete *.* localpath
cd ..
cd newdirectory
get -delete *.* newlocalpath
___________________
hm and my logfile is very huge OSmile
could anybody help me or give me a hint to get a logfile looking like that one in the other topic?
I do not see any lost in the thread you link. There's just a captured output of the script console.
Have you checked XML logging?
hi and thanks for your reply!
i want a logfile which is looking like:
date and time
connection succesfull
get file 1 100%
delete file 1 sucessfull
.. file 2 ..
.. file 2 ..
file n
the script is starting about every hour and the new log should be integrated in the old log file.
i have read the xml logging docu three times and tried to get some infos by google, after some tries a stopped finding a working solution Sad
Otherwise i think i can't use xml logging, because there are some other operations from the batchfile which are logged too. I wish they are in the same logfile like winscp-logs.
Sorry for my bad english and chaotic writing.
greetings - andreas
Mindy
sorry, me again.
In my logfiles or on cmd.exe window there is nowhere an 100% or s.th like this.
date and time
get file 1 100%
This is contained in XML log.
Post example how your output from cmd.exe looks like for file transfers.
mindy
hi there! thanks for re-answering.
my cmd output looks very simple o.O
M:\>WinSCP.com /script=f5script.txt /log=f5log.txt
batch on
confirm off
Searching for host...
Connecting to host...
Authenticating...
Using username "USER".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] USER@host
/incoming/dir1
file_1.p12
/incoming
/incoming/dir2
file_2.p12
hmh, any ideas?
Thanks for your post. This issue has been added to tracker.
mindy
hm and another solution? think i have to get help with xml :- /
mindy
do you have an idea, in which version (when) you'll implement the transfer logs?
