Topic "Paste context menu"
jpm1
Hi , i use WinSCP for several monthes now . i chose it because it's free and after several monthes of using it i have to say it's a cool prog . There's a function that i think is missing , that i miss a lot at least Smile it's paste in context menu each time you need to go in files if you have lot of files to manipulate it's not much evident
Cheers .
Do you mean pasting to remote directory? Where do you want to copy from?
jpm1
pasting from clipboard to remote directory
OK, but what do you have in your clipboard?
jpm1
I would like to be able to copy a file (html , rar ..) from the clipboard to the remote directory with the right click (paste in remote folder context menu)
I really need to understand your use case. Can you give me answer longer than few words? Where do you get the file from? Local drive? Remote path?
jpm1
Hi ,
1/ copy a file from HD (right click)
2/ right click on WinSCP remote path
3/ paste the file in remote
Cheers
OK, request for this kind of operation is being tracked already.
ADTC
The more appropriate/specific tracker will be #422. Also see this issue.
[On a sidenote, it will be nice if the trackers had a voting system, so we could vote up those trackers we care about, and that will somehow translate to priority.]
