Topic "files missing"
krm2009
Hello All,
I actually wanted to copy the files to a shared drive, but by mistake I did not copy the full path, one of the forward slashes was not copied while I did a move to. Now the file is not found in the target loacation nor at the place from where I did move to.
This is WinSCP Ver 4.2.2.
If some one can throw some light as to where and how I could retrieve the files it will be much appreciated.
krm2009
So what was the path you have actually used?
krm2009
It is a internal shared drive subfolder.SO if an error was encountered in the directory then should'nt there be some kind of error message.
Please advise.
OK, but can you post the path literally? I cannot help you otherwise.
