SFTP upload process
SeanF12
SFTP upload process
We have a batch file that uploads files via the command line. It's pretty simple...it makes the connection to the host, uplaods the files and disconnects. It works almost all of the time, but intermittently we notice that the files we are uploading never make it to the source. I am seeing the following in the log files when it fails:
. 2009-08-21 06:30:07.530 --------------------------------------------------------------------------
. 2009-08-21 06:30:07.545 WinSCP Version 4.1.6 (Build 412) (OS 5.0.2195 Service Pack 4)
. 2009-08-21 06:30:07.545 Login time: Friday, August 21, 2009 6:30:07 AM
. 2009-08-21 06:30:07.545 --------------------------------------------------------------------------
. 2009-08-21 06:30:07.561 Session name: smt_adm
. 2009-08-21 06:30:07.561 Host name: interfaces.umassadmin.net (Port: 22)
. 2009-08-21 06:30:07.561 User name: smt_adm (Password: Yes, Key file: No)
. 2009-08-21 06:30:07.561 Tunnel: No
. 2009-08-21 06:30:07.561 Transfer Protocol: SFTP (SCP)
. 2009-08-21 06:30:07.561 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-08-21 06:30:07.561 Proxy: none
. 2009-08-21 06:30:07.561 SSH protocol version: 2; Compression: No
. 2009-08-21 06:30:07.561 Bypass authentication: No
. 2009-08-21 06:30:07.561 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-08-21 06:30:07.561 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-08-21 06:30:07.561 SSH Bugs: -,-,-,-,-,-,-,-
. 2009-08-21 06:30:07.561 SFTP Bugs: -,-
. 2009-08-21 06:30:07.561 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-08-21 06:30:07.561 Shell: default, EOL: 0
. 2009-08-21 06:30:07.561 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-08-21 06:30:07.561 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-08-21 06:30:07.561 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-08-21 06:30:07.561 Cache directory changes: Yes, Permanent: Yes
. 2009-08-21 06:30:07.561 DST mode: 1
. 2009-08-21 06:30:07.561 --------------------------------------------------------------------------
. 2009-08-21 06:30:07.561 Looking up host "interfaces.umassadmin.net"
. 2009-08-21 06:30:07.795 Connecting to 146.189.117.173 port 22
. 2009-08-21 06:30:07.858 Server version: SSH-2.0-4.4.6.43 SSH Secure Shell
. 2009-08-21 06:30:07.858 We claim version: SSH-2.0-WinSCP_release_4.1.6
. 2009-08-21 06:30:07.905 SSPI: acquired credentials for: svcschedtask@UMASSMEDNET.NET
. 2009-08-21 06:30:07.905 Constructed service principal name 'host/interfaces.umassadmin.net'
. 2009-08-21 06:30:07.920 GSSKEX disabled: The specified target is unknown or unreachable
. 2009-08-21 06:30:07.920 Using SSH protocol version 2
. 2009-08-21 06:30:07.920 Using Diffie-Hellman with standard group "group1"
. 2009-08-21 06:30:07.920 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-08-21 06:30:08.342 Host key fingerprint is:
. 2009-08-21 06:30:08.342 ssh-dss 2048 48:6c:7f:14:1f:f4:4f:ca:aa:e7:e7:c4:f5:b9:4d:02
. 2009-08-21 06:30:08.342 Initialised AES-256 CBC client->server encryption
. 2009-08-21 06:30:08.342 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-08-21 06:30:08.342 Initialised AES-256 CBC server->client encryption
. 2009-08-21 06:30:08.342 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-08-21 06:30:08.405 Using username "smt_adm".
. 2009-08-21 06:30:08.420 Prompt (6, SSH password, , &Password: )
. 2009-08-21 06:30:08.420 Using stored password.
. 2009-08-21 06:30:08.420 Sent password
. 2009-08-21 06:30:08.436 Access granted
. 2009-08-21 06:30:08.436 Opened channel for session
. 2009-08-21 06:30:08.436 Started a shell/command
. 2009-08-21 06:30:08.436 --------------------------------------------------------------------------
. 2009-08-21 06:30:08.436 Using SFTP protocol.
. 2009-08-21 06:30:08.436 Doing startup conversation with host.
> 2009-08-21 06:30:08.451 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-08-21 06:30:08.451 Type: SSH_FXP_VERSION, Size: 58, Number: -1
. 2009-08-21 06:30:08.451 SFTP version 3 negotiated.
. 2009-08-21 06:30:08.451 Unknown server extension newline@vandyke.com=0x0A
. 2009-08-21 06:30:08.451 Unknown server extension umask@ssh.com=0x00000012
. 2009-08-21 06:30:08.451 We believe the server has signed timestamps bug
. 2009-08-21 06:30:08.451 We will use UTF-8 strings for status messages only
. 2009-08-21 06:30:08.451 Getting current directory name.
. 2009-08-21 06:30:08.467 Getting real path for '.'
> 2009-08-21 06:30:08.467 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-08-21 06:30:08.467 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2009-08-21 06:30:08.467 Real path is '/'
. 2009-08-21 06:30:08.467 Startup conversation with host finished.
. 2009-08-21 06:30:08.576 Copying 159 files/directories to remote directory "/"
. 2009-08-21 06:30:08.576 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2009-08-21 06:30:08.576 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2009-08-21 06:30:08.576 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-08-21 06:30:08.592 File: "E:\SMT_MIL\data\BostonHarrisOLC.txt"
. 2009-08-21 06:30:08.623 Copying "E:\SMT_MIL\data\BostonHarrisOLC.txt" to remote directory started.
. 2009-08-21 06:30:08.623 Ascii transfer mode selected.
. 2009-08-21 06:30:08.623 Opening remote file.
> 2009-08-21 06:30:08.623 Type: SSH_FXP_OPEN, Size: 45, Number: 259
< 2009-08-21 06:30:08.623 Type: SSH_FXP_HANDLE, Size: 17, Number: 259
> 2009-08-21 06:30:08.639 Type: SSH_FXP_WRITE, Size: 4124, Number: 774
. 2009-08-21 06:30:08.951 67 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:30:08.951 Type: SSH_FXP_CLOSE, Size: 17, Number: 9988
> 2009-08-21 06:30:08.951 Type: SSH_FXP_SETSTAT, Size: 41, Number: 521
< 2009-08-21 06:30:08.967 Type: SSH_FXP_STATUS, Size: 21, Number: 8966
< 2009-08-21 06:30:08.967 Type: SSH_FXP_STATUS, Size: 21, Number: 9222
< 2009-08-21 06:30:09.170 Type: SSH_FXP_STATUS, Size: 21, Number: 9478
< 2009-08-21 06:30:09.170 Type: SSH_FXP_STATUS, Size: 21, Number: 9734
< 2009-08-21 06:30:09.170 Type: SSH_FXP_STATUS, Size: 21, Number: 9988
< 2009-08-21 06:30:09.170 Status/error code: 0
< 2009-08-21 06:30:09.170 Type: SSH_FXP_STATUS, Size: 21, Number: 521
. 2009-08-21 06:30:09.170 File: "E:\SMT_MIL\data\bos_account_cae.txt"
. 2009-08-21 06:30:09.170 Copying "E:\SMT_MIL\data\bos_account_cae.txt" to remote directory started.
. 2009-08-21 06:30:09.170 Ascii transfer mode selected.
. 2009-08-21 06:30:09.170 Opening remote file.
> 2009-08-21 06:30:09.170 Type: SSH_FXP_OPEN, Size: 45, Number: 10243
< 2009-08-21 06:30:09.170 Type: SSH_FXP_HANDLE, Size: 17, Number: 10243
> 2009-08-21 06:30:09.186 Type: SSH_FXP_WRITE, Size: 5464, Number: 10758
> 2009-08-21 06:30:09.186 Type: SSH_FXP_CLOSE, Size: 17, Number: 11012
> 2009-08-21 06:30:09.186 Type: SSH_FXP_SETSTAT, Size: 41, Number: 10505
< 2009-08-21 06:30:09.186 Type: SSH_FXP_STATUS, Size: 21, Number: 10758
< 2009-08-21 06:30:09.186 Type: SSH_FXP_STATUS, Size: 21, Number: 11012
< 2009-08-21 06:30:09.186 Status/error code: 0
< 2009-08-21 06:30:09.186 Type: SSH_FXP_STATUS, Size: 21, Number: 10505
. 2009-08-21 06:30:09.233 File: "E:\SMT_MIL\data\bos_address.txt"
. 2009-08-21 06:30:09.233 Copying "E:\SMT_MIL\data\bos_address.txt" to remote directory started.
. 2009-08-21 06:30:09.233 Ascii transfer mode selected.
. 2009-08-21 06:30:09.233 Opening remote file.
> 2009-08-21 06:30:09.233 Type: SSH_FXP_OPEN, Size: 41, Number: 11267
< 2009-08-21 06:30:09.233 Type: SSH_FXP_HANDLE, Size: 17, Number: 11267
> 2009-08-21 06:30:09.248 Type: SSH_FXP_WRITE, Size: 16367, Number: 11782
. 2009-08-21 06:32:17.982 24391 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:32:17.997 Type: SSH_FXP_CLOSE, Size: 17, Number: 3134468
> 2009-08-21 06:32:17.997 Type: SSH_FXP_SETSTAT, Size: 37, Number: 11529
< 2009-08-21 06:32:18.013 Type: SSH_FXP_STATUS, Size: 21, Number: 3133446
< 2009-08-21 06:32:18.232 Type: SSH_FXP_STATUS, Size: 21, Number: 3133702
< 2009-08-21 06:32:18.232 Type: SSH_FXP_STATUS, Size: 21, Number: 3133958
< 2009-08-21 06:32:18.232 Type: SSH_FXP_STATUS, Size: 21, Number: 3134214
< 2009-08-21 06:32:18.232 Type: SSH_FXP_STATUS, Size: 21, Number: 3134468
< 2009-08-21 06:32:18.232 Status/error code: 0
< 2009-08-21 06:32:18.232 Type: SSH_FXP_STATUS, Size: 21, Number: 11529
. 2009-08-21 06:32:18.232 File: "E:\SMT_MIL\data\bos_address_types.txt"
. 2009-08-21 06:32:18.247 Copying "E:\SMT_MIL\data\bos_address_types.txt" to remote directory started.
. 2009-08-21 06:32:18.247 Ascii transfer mode selected.
. 2009-08-21 06:32:18.247 Opening remote file.
> 2009-08-21 06:32:18.247 Type: SSH_FXP_OPEN, Size: 47, Number: 3134723
< 2009-08-21 06:32:18.247 Type: SSH_FXP_HANDLE, Size: 17, Number: 3134723
> 2009-08-21 06:32:18.263 Type: SSH_FXP_WRITE, Size: 4645, Number: 3135238
> 2009-08-21 06:32:18.279 Type: SSH_FXP_CLOSE, Size: 17, Number: 3135492
> 2009-08-21 06:32:18.279 Type: SSH_FXP_SETSTAT, Size: 43, Number: 3134985
< 2009-08-21 06:32:18.279 Type: SSH_FXP_STATUS, Size: 21, Number: 3135238
< 2009-08-21 06:32:18.451 Type: SSH_FXP_STATUS, Size: 21, Number: 3135492
< 2009-08-21 06:32:18.451 Status/error code: 0
< 2009-08-21 06:32:18.451 Type: SSH_FXP_STATUS, Size: 21, Number: 3134985
. 2009-08-21 06:32:18.466 File: "E:\SMT_MIL\data\bos_attribute.txt"
. 2009-08-21 06:32:18.482 Copying "E:\SMT_MIL\data\bos_attribute.txt" to remote directory started.
. 2009-08-21 06:32:18.482 Ascii transfer mode selected.
. 2009-08-21 06:32:18.482 Opening remote file.
> 2009-08-21 06:32:18.482 Type: SSH_FXP_OPEN, Size: 43, Number: 3135747
< 2009-08-21 06:32:18.482 Type: SSH_FXP_HANDLE, Size: 17, Number: 3135747
> 2009-08-21 06:32:18.513 Type: SSH_FXP_WRITE, Size: 16333, Number: 3136262
. 2009-08-21 06:33:12.106 9973 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:33:12.106 Type: SSH_FXP_CLOSE, Size: 17, Number: 4413444
> 2009-08-21 06:33:12.106 Type: SSH_FXP_SETSTAT, Size: 39, Number: 3136009
< 2009-08-21 06:33:12.263 Type: SSH_FXP_STATUS, Size: 21, Number: 4412422
< 2009-08-21 06:33:12.263 Type: SSH_FXP_STATUS, Size: 21, Number: 4412678
< 2009-08-21 06:33:12.263 Type: SSH_FXP_STATUS, Size: 21, Number: 4412934
< 2009-08-21 06:33:12.263 Type: SSH_FXP_STATUS, Size: 21, Number: 4413190
< 2009-08-21 06:33:12.263 Type: SSH_FXP_STATUS, Size: 21, Number: 4413444
< 2009-08-21 06:33:12.263 Status/error code: 0
< 2009-08-21 06:33:12.263 Type: SSH_FXP_STATUS, Size: 21, Number: 3136009
. 2009-08-21 06:33:12.278 File: "E:\SMT_MIL\data\bos_attribute_types.txt"
. 2009-08-21 06:33:12.310 Copying "E:\SMT_MIL\data\bos_attribute_types.txt" to remote directory started.
. 2009-08-21 06:33:12.310 Ascii transfer mode selected.
. 2009-08-21 06:33:12.310 Opening remote file.
> 2009-08-21 06:33:12.310 Type: SSH_FXP_OPEN, Size: 49, Number: 4413699
< 2009-08-21 06:33:12.310 Type: SSH_FXP_HANDLE, Size: 17, Number: 4413699
> 2009-08-21 06:33:12.325 Type: SSH_FXP_WRITE, Size: 16313, Number: 4414214
. 2009-08-21 06:33:12.466 22 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:33:12.466 Type: SSH_FXP_CLOSE, Size: 17, Number: 4418052
> 2009-08-21 06:33:12.466 Type: SSH_FXP_SETSTAT, Size: 45, Number: 4413961
< 2009-08-21 06:33:12.481 Type: SSH_FXP_STATUS, Size: 21, Number: 4416262
< 2009-08-21 06:33:12.481 Type: SSH_FXP_STATUS, Size: 21, Number: 4416518
< 2009-08-21 06:33:12.481 Type: SSH_FXP_STATUS, Size: 21, Number: 4416774
< 2009-08-21 06:33:12.481 Type: SSH_FXP_STATUS, Size: 21, Number: 4417030
< 2009-08-21 06:33:12.481 Type: SSH_FXP_STATUS, Size: 21, Number: 4417286
< 2009-08-21 06:33:12.481 Type: SSH_FXP_STATUS, Size: 21, Number: 4417542
< 2009-08-21 06:33:12.700 Type: SSH_FXP_STATUS, Size: 21, Number: 4417798
< 2009-08-21 06:33:12.700 Type: SSH_FXP_STATUS, Size: 21, Number: 4418052
< 2009-08-21 06:33:12.700 Status/error code: 0
< 2009-08-21 06:33:12.700 Type: SSH_FXP_STATUS, Size: 21, Number: 4413961
. 2009-08-21 06:33:12.716 File: "E:\SMT_MIL\data\bos_cae_categories.txt"
. 2009-08-21 06:33:12.716 Copying "E:\SMT_MIL\data\bos_cae_categories.txt" to remote directory started.
. 2009-08-21 06:33:12.716 Ascii transfer mode selected.
. 2009-08-21 06:33:12.716 Opening remote file.
> 2009-08-21 06:33:12.716 Type: SSH_FXP_OPEN, Size: 48, Number: 4418307
< 2009-08-21 06:33:12.716 Type: SSH_FXP_HANDLE, Size: 17, Number: 4418307
> 2009-08-21 06:33:12.731 Type: SSH_FXP_WRITE, Size: 1346, Number: 4418822
> 2009-08-21 06:33:12.731 Type: SSH_FXP_CLOSE, Size: 17, Number: 4419076
> 2009-08-21 06:33:12.731 Type: SSH_FXP_SETSTAT, Size: 44, Number: 4418569
< 2009-08-21 06:33:12.778 Type: SSH_FXP_STATUS, Size: 21, Number: 4418822
< 2009-08-21 06:33:12.778 Type: SSH_FXP_STATUS, Size: 21, Number: 4419076
< 2009-08-21 06:33:12.778 Status/error code: 0
< 2009-08-21 06:33:12.778 Type: SSH_FXP_STATUS, Size: 21, Number: 4418569
. 2009-08-21 06:33:12.778 File: "E:\SMT_MIL\data\bos_campaigns.txt"
. 2009-08-21 06:33:12.810 Copying "E:\SMT_MIL\data\bos_campaigns.txt" to remote directory started.
. 2009-08-21 06:33:12.810 Ascii transfer mode selected.
. 2009-08-21 06:33:12.810 Opening remote file.
> 2009-08-21 06:33:12.810 Type: SSH_FXP_OPEN, Size: 43, Number: 4419331
< 2009-08-21 06:33:12.810 Type: SSH_FXP_HANDLE, Size: 17, Number: 4419331
> 2009-08-21 06:33:12.825 Type: SSH_FXP_WRITE, Size: 2213, Number: 4419846
> 2009-08-21 06:33:12.825 Type: SSH_FXP_CLOSE, Size: 17, Number: 4420100
> 2009-08-21 06:33:12.825 Type: SSH_FXP_SETSTAT, Size: 39, Number: 4419593
< 2009-08-21 06:33:12.825 Type: SSH_FXP_STATUS, Size: 21, Number: 4419846
< 2009-08-21 06:33:12.825 Type: SSH_FXP_STATUS, Size: 21, Number: 4420100
< 2009-08-21 06:33:12.825 Status/error code: 0
< 2009-08-21 06:33:12.825 Type: SSH_FXP_STATUS, Size: 21, Number: 4419593
. 2009-08-21 06:33:12.841 File: "E:\SMT_MIL\data\bos_campaign_goals.txt"
. 2009-08-21 06:33:12.841 Copying "E:\SMT_MIL\data\bos_campaign_goals.txt" to remote directory started.
. 2009-08-21 06:33:12.841 Ascii transfer mode selected.
. 2009-08-21 06:33:12.841 Opening remote file.
> 2009-08-21 06:33:12.841 Type: SSH_FXP_OPEN, Size: 48, Number: 4420355
< 2009-08-21 06:33:12.841 Type: SSH_FXP_HANDLE, Size: 17, Number: 4420355
> 2009-08-21 06:33:12.841 Type: SSH_FXP_WRITE, Size: 426, Number: 4420870
> 2009-08-21 06:33:12.841 Type: SSH_FXP_CLOSE, Size: 17, Number: 4421124
> 2009-08-21 06:33:12.841 Type: SSH_FXP_SETSTAT, Size: 44, Number: 4420617
< 2009-08-21 06:33:12.841 Type: SSH_FXP_STATUS, Size: 21, Number: 4420870
< 2009-08-21 06:33:12.856 Type: SSH_FXP_STATUS, Size: 21, Number: 4421124
< 2009-08-21 06:33:12.856 Status/error code: 0
< 2009-08-21 06:33:12.856 Type: SSH_FXP_STATUS, Size: 21, Number: 4420617
. 2009-08-21 06:33:12.856 File: "E:\SMT_MIL\data\bos_chart_of_accounts.txt"
. 2009-08-21 06:33:12.872 Copying "E:\SMT_MIL\data\bos_chart_of_accounts.txt" to remote directory started.
. 2009-08-21 06:33:12.872 Ascii transfer mode selected.
. 2009-08-21 06:33:12.872 Opening remote file.
> 2009-08-21 06:33:12.872 Type: SSH_FXP_OPEN, Size: 51, Number: 4421379
< 2009-08-21 06:33:12.872 Type: SSH_FXP_HANDLE, Size: 17, Number: 4421379
> 2009-08-21 06:33:12.888 Type: SSH_FXP_WRITE, Size: 16348, Number: 4421894
. 2009-08-21 06:33:13.122 43 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:33:13.122 Type: SSH_FXP_CLOSE, Size: 17, Number: 4428036
> 2009-08-21 06:33:13.122 Type: SSH_FXP_SETSTAT, Size: 47, Number: 4421641
< 2009-08-21 06:33:13.138 Type: SSH_FXP_STATUS, Size: 21, Number: 4427014
< 2009-08-21 06:33:13.138 Type: SSH_FXP_STATUS, Size: 21, Number: 4427270
< 2009-08-21 06:33:13.356 Type: SSH_FXP_STATUS, Size: 21, Number: 4427526
< 2009-08-21 06:33:13.356 Type: SSH_FXP_STATUS, Size: 21, Number: 4427782
< 2009-08-21 06:33:13.356 Type: SSH_FXP_STATUS, Size: 21, Number: 4428036
< 2009-08-21 06:33:13.356 Status/error code: 0
< 2009-08-21 06:33:13.356 Type: SSH_FXP_STATUS, Size: 21, Number: 4421641
. 2009-08-21 06:33:13.356 File: "E:\SMT_MIL\data\bos_constituent_types.txt"
. 2009-08-21 06:33:13.356 Copying "E:\SMT_MIL\data\bos_constituent_types.txt" to remote directory started.
. 2009-08-21 06:33:13.356 Ascii transfer mode selected.
. 2009-08-21 06:33:13.356 Opening remote file.
> 2009-08-21 06:33:13.356 Type: SSH_FXP_OPEN, Size: 51, Number: 4428291
< 2009-08-21 06:33:13.356 Type: SSH_FXP_HANDLE, Size: 17, Number: 4428291
> 2009-08-21 06:33:13.372 Type: SSH_FXP_WRITE, Size: 7046, Number: 4428806
> 2009-08-21 06:33:13.388 Type: SSH_FXP_CLOSE, Size: 17, Number: 4429060
> 2009-08-21 06:33:13.388 Type: SSH_FXP_SETSTAT, Size: 47, Number: 4428553
< 2009-08-21 06:33:13.388 Type: SSH_FXP_STATUS, Size: 21, Number: 4428806
< 2009-08-21 06:33:13.388 Type: SSH_FXP_STATUS, Size: 21, Number: 4429060
< 2009-08-21 06:33:13.388 Status/error code: 0
< 2009-08-21 06:33:13.575 Type: SSH_FXP_STATUS, Size: 21, Number: 4428553
< 2009-08-21 06:33:13.575 Status/error code: 0
. 2009-08-21 06:33:13.591 File: "E:\SMT_MIL\data\bos_corebio.txt"
. 2009-08-21 06:33:13.606 Copying "E:\SMT_MIL\data\bos_corebio.txt" to remote directory started.
. 2009-08-21 06:33:13.606 Ascii transfer mode selected.
. 2009-08-21 06:33:13.606 Opening remote file.
> 2009-08-21 06:33:13.606 Type: SSH_FXP_OPEN, Size: 41, Number: 4429315
< 2009-08-21 06:33:13.606 Type: SSH_FXP_HANDLE, Size: 17, Number: 4429315
> 2009-08-21 06:33:13.622 Type: SSH_FXP_WRITE, Size: 16362, Number: 4429830
. 2009-08-21 06:34:18.981 12306 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:34:18.981 Type: SSH_FXP_CLOSE, Size: 17, Number: 6005764
< 2009-08-21 06:34:18.981 Type: SSH_FXP_STATUS, Size: 21, Number: 6004486
< 2009-08-21 06:34:18.981 Status/error code: 0
< 2009-08-21 06:34:18.981 Type: SSH_FXP_STATUS, Size: 21, Number: 6004742
> 2009-08-21 06:34:18.981 Type: SSH_FXP_SETSTAT, Size: 37, Number: 4429577
< 2009-08-21 06:34:18.981 Type: SSH_FXP_STATUS, Size: 21, Number: 6004998
< 2009-08-21 06:34:19.309 Type: SSH_FXP_STATUS, Size: 21, Number: 6005254
< 2009-08-21 06:34:19.309 Type: SSH_FXP_STATUS, Size: 21, Number: 6005510
< 2009-08-21 06:34:19.309 Type: SSH_FXP_STATUS, Size: 21, Number: 6005764
< 2009-08-21 06:34:19.309 Status/error code: 0
< 2009-08-21 06:34:19.309 Type: SSH_FXP_STATUS, Size: 21, Number: 4429577
. 2009-08-21 06:34:19.340 File: "E:\SMT_MIL\data\bos_death.txt"
. 2009-08-21 06:34:19.340 Copying "E:\SMT_MIL\data\bos_death.txt" to remote directory started.
. 2009-08-21 06:34:19.340 Ascii transfer mode selected.
. 2009-08-21 06:34:19.340 Opening remote file.
> 2009-08-21 06:34:19.340 Type: SSH_FXP_OPEN, Size: 39, Number: 6006019
< 2009-08-21 06:34:19.340 Type: SSH_FXP_HANDLE, Size: 17, Number: 6006019
> 2009-08-21 06:34:19.356 Type: SSH_FXP_WRITE, Size: 16308, Number: 6006534
. 2009-08-21 06:34:20.247 164 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:34:20.247 Type: SSH_FXP_CLOSE, Size: 17, Number: 6028036
> 2009-08-21 06:34:20.247 Type: SSH_FXP_SETSTAT, Size: 35, Number: 6006281
< 2009-08-21 06:34:20.262 Type: SSH_FXP_STATUS, Size: 21, Number: 6027270
< 2009-08-21 06:34:20.262 Type: SSH_FXP_STATUS, Size: 21, Number: 6027526
< 2009-08-21 06:34:20.403 Type: SSH_FXP_STATUS, Size: 21, Number: 6027782
< 2009-08-21 06:34:20.403 Type: SSH_FXP_STATUS, Size: 21, Number: 6028036
< 2009-08-21 06:34:20.403 Status/error code: 0
< 2009-08-21 06:34:20.403 Type: SSH_FXP_STATUS, Size: 21, Number: 6006281
. 2009-08-21 06:34:20.419 File: "E:\SMT_MIL\data\bos_degrees.txt"
. 2009-08-21 06:34:20.419 Copying "E:\SMT_MIL\data\bos_degrees.txt" to remote directory started.
. 2009-08-21 06:34:20.419 Ascii transfer mode selected.
. 2009-08-21 06:34:20.419 Opening remote file.
> 2009-08-21 06:34:20.419 Type: SSH_FXP_OPEN, Size: 41, Number: 6028291
< 2009-08-21 06:34:20.419 Type: SSH_FXP_HANDLE, Size: 17, Number: 6028291
> 2009-08-21 06:34:20.434 Type: SSH_FXP_WRITE, Size: 5370, Number: 6028806
> 2009-08-21 06:34:20.434 Type: SSH_FXP_CLOSE, Size: 17, Number: 6029060
> 2009-08-21 06:34:20.434 Type: SSH_FXP_SETSTAT, Size: 37, Number: 6028553
< 2009-08-21 06:34:20.434 Type: SSH_FXP_STATUS, Size: 21, Number: 6028806
< 2009-08-21 06:34:20.622 Type: SSH_FXP_STATUS, Size: 21, Number: 6029060
< 2009-08-21 06:34:20.622 Status/error code: 0
< 2009-08-21 06:34:20.622 Type: SSH_FXP_STATUS, Size: 21, Number: 6028553
. 2009-08-21 06:34:20.637 File: "E:\SMT_MIL\data\bos_gifts.txt"
. 2009-08-21 06:34:20.637 Copying "E:\SMT_MIL\data\bos_gifts.txt" to remote directory started.
. 2009-08-21 06:34:20.637 Ascii transfer mode selected.
. 2009-08-21 06:34:20.653 Opening remote file.
> 2009-08-21 06:34:20.653 Type: SSH_FXP_OPEN, Size: 39, Number: 6029315
< 2009-08-21 06:34:20.653 Type: SSH_FXP_HANDLE, Size: 17, Number: 6029315
> 2009-08-21 06:34:20.669 Type: SSH_FXP_WRITE, Size: 16365, Number: 6029830
. 2009-08-21 06:36:24.371 23967 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:36:24.371 Type: SSH_FXP_CLOSE, Size: 17, Number: 9098244
> 2009-08-21 06:36:24.371 Type: SSH_FXP_SETSTAT, Size: 35, Number: 6029577
< 2009-08-21 06:36:24.387 Type: SSH_FXP_STATUS, Size: 21, Number: 9097222
< 2009-08-21 06:36:24.387 Type: SSH_FXP_STATUS, Size: 21, Number: 9097478
< 2009-08-21 06:36:24.543 Type: SSH_FXP_STATUS, Size: 21, Number: 9097734
< 2009-08-21 06:36:24.543 Type: SSH_FXP_STATUS, Size: 21, Number: 9097990
< 2009-08-21 06:36:24.543 Type: SSH_FXP_STATUS, Size: 21, Number: 9098244
< 2009-08-21 06:36:24.543 Status/error code: 0
< 2009-08-21 06:36:24.543 Type: SSH_FXP_STATUS, Size: 21, Number: 6029577
. 2009-08-21 06:36:24.543 File: "E:\SMT_MIL\data\bos_gift_types.txt"
. 2009-08-21 06:36:24.558 Copying "E:\SMT_MIL\data\bos_gift_types.txt" to remote directory started.
. 2009-08-21 06:36:24.558 Ascii transfer mode selected.
. 2009-08-21 06:36:24.558 Opening remote file.
> 2009-08-21 06:36:24.558 Type: SSH_FXP_OPEN, Size: 44, Number: 9098499
< 2009-08-21 06:36:24.558 Type: SSH_FXP_HANDLE, Size: 17, Number: 9098499
> 2009-08-21 06:36:24.574 Type: SSH_FXP_WRITE, Size: 9994, Number: 9099014
> 2009-08-21 06:36:24.574 Type: SSH_FXP_CLOSE, Size: 17, Number: 9099268
> 2009-08-21 06:36:24.574 Type: SSH_FXP_SETSTAT, Size: 40, Number: 9098761
< 2009-08-21 06:36:24.590 Type: SSH_FXP_STATUS, Size: 21, Number: 9099014
< 2009-08-21 06:36:24.590 Type: SSH_FXP_STATUS, Size: 21, Number: 9099268
< 2009-08-21 06:36:24.590 Status/error code: 0
< 2009-08-21 06:36:24.590 Type: SSH_FXP_STATUS, Size: 21, Number: 9098761
. 2009-08-21 06:36:24.605 File: "E:\SMT_MIL\data\bos_institutions.txt"
. 2009-08-21 06:36:24.621 Copying "E:\SMT_MIL\data\bos_institutions.txt" to remote directory started.
. 2009-08-21 06:36:24.621 Ascii transfer mode selected.
. 2009-08-21 06:36:24.621 Opening remote file.
> 2009-08-21 06:36:24.621 Type: SSH_FXP_OPEN, Size: 46, Number: 9099523
< 2009-08-21 06:36:24.621 Type: SSH_FXP_HANDLE, Size: 17, Number: 9099523
> 2009-08-21 06:36:24.637 Type: SSH_FXP_WRITE, Size: 16292, Number: 9100038
. 2009-08-21 06:36:24.730 16 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:36:24.730 Type: SSH_FXP_CLOSE, Size: 17, Number: 9102596
> 2009-08-21 06:36:24.730 Type: SSH_FXP_SETSTAT, Size: 42, Number: 9099785
< 2009-08-21 06:36:24.762 Type: SSH_FXP_STATUS, Size: 21, Number: 9101830
< 2009-08-21 06:36:24.980 Type: SSH_FXP_STATUS, Size: 21, Number: 9102086
< 2009-08-21 06:36:24.980 Type: SSH_FXP_STATUS, Size: 21, Number: 9102342
< 2009-08-21 06:36:24.980 Type: SSH_FXP_STATUS, Size: 21, Number: 9102596
< 2009-08-21 06:36:24.980 Status/error code: 0
< 2009-08-21 06:36:24.980 Type: SSH_FXP_STATUS, Size: 21, Number: 9099785
. 2009-08-21 06:36:24.980 File: "E:\SMT_MIL\data\bos_mill.txt"
. 2009-08-21 06:36:24.980 Copying "E:\SMT_MIL\data\bos_mill.txt" to remote directory started.
. 2009-08-21 06:36:24.980 Ascii transfer mode selected.
. 2009-08-21 06:36:24.980 Opening remote file.
> 2009-08-21 06:36:24.980 Type: SSH_FXP_OPEN, Size: 38, Number: 9102851
< 2009-08-21 06:36:24.996 Type: SSH_FXP_HANDLE, Size: 17, Number: 9102851
> 2009-08-21 06:36:24.996 Type: SSH_FXP_WRITE, Size: 53, Number: 9103366
> 2009-08-21 06:36:24.996 Type: SSH_FXP_CLOSE, Size: 17, Number: 9103620
> 2009-08-21 06:36:24.996 Type: SSH_FXP_SETSTAT, Size: 34, Number: 9103113
< 2009-08-21 06:36:24.996 Type: SSH_FXP_STATUS, Size: 21, Number: 9103366
< 2009-08-21 06:36:24.996 Type: SSH_FXP_STATUS, Size: 21, Number: 9103620
< 2009-08-21 06:36:24.996 Status/error code: 0
< 2009-08-21 06:36:24.996 Type: SSH_FXP_STATUS, Size: 21, Number: 9103113
. 2009-08-21 06:36:25.012 File: "E:\SMT_MIL\data\bos_name.txt"
. 2009-08-21 06:36:25.027 Copying "E:\SMT_MIL\data\bos_name.txt" to remote directory started.
. 2009-08-21 06:36:25.027 Ascii transfer mode selected.
. 2009-08-21 06:36:25.027 Opening remote file.
> 2009-08-21 06:36:25.027 Type: SSH_FXP_OPEN, Size: 38, Number: 9103875
< 2009-08-21 06:36:25.027 Type: SSH_FXP_HANDLE, Size: 17, Number: 9103875
> 2009-08-21 06:36:25.043 Type: SSH_FXP_WRITE, Size: 16362, Number: 9104390
. 2009-08-21 06:37:49.198 16079 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:37:49.198 Type: SSH_FXP_CLOSE, Size: 17, Number: 11163140
> 2009-08-21 06:37:49.198 Type: SSH_FXP_SETSTAT, Size: 34, Number: 9104137
< 2009-08-21 06:37:49.214 Type: SSH_FXP_STATUS, Size: 21, Number: 11162118
< 2009-08-21 06:37:49.417 Type: SSH_FXP_STATUS, Size: 21, Number: 11162374
< 2009-08-21 06:37:49.417 Type: SSH_FXP_STATUS, Size: 21, Number: 11162630
< 2009-08-21 06:37:49.417 Type: SSH_FXP_STATUS, Size: 21, Number: 11162886
< 2009-08-21 06:37:49.417 Type: SSH_FXP_STATUS, Size: 21, Number: 11163140
< 2009-08-21 06:37:49.417 Status/error code: 0
< 2009-08-21 06:37:49.417 Type: SSH_FXP_STATUS, Size: 21, Number: 9104137
. 2009-08-21 06:37:49.433 File: "E:\SMT_MIL\data\bos_plannedgifts.txt"
. 2009-08-21 06:37:49.433 Copying "E:\SMT_MIL\data\bos_plannedgifts.txt" to remote directory started.
. 2009-08-21 06:37:49.433 Ascii transfer mode selected.
. 2009-08-21 06:37:49.433 Opening remote file.
> 2009-08-21 06:37:49.433 Type: SSH_FXP_OPEN, Size: 46, Number: 11163395
< 2009-08-21 06:37:49.448 Type: SSH_FXP_HANDLE, Size: 17, Number: 11163395
> 2009-08-21 06:37:49.448 Type: SSH_FXP_WRITE, Size: 1186, Number: 11163910
> 2009-08-21 06:37:49.448 Type: SSH_FXP_CLOSE, Size: 17, Number: 11164164
> 2009-08-21 06:37:49.448 Type: SSH_FXP_SETSTAT, Size: 42, Number: 11163657
< 2009-08-21 06:37:49.495 Type: SSH_FXP_STATUS, Size: 21, Number: 11163910
< 2009-08-21 06:37:49.495 Type: SSH_FXP_STATUS, Size: 21, Number: 11164164
< 2009-08-21 06:37:49.495 Status/error code: 0
< 2009-08-21 06:37:49.495 Type: SSH_FXP_STATUS, Size: 21, Number: 11163657
. 2009-08-21 06:37:49.511 File: "E:\SMT_MIL\data\bos_plannedgifts_lookup2.txt"
. 2009-08-21 06:37:49.511 Copying "E:\SMT_MIL\data\bos_plannedgifts_lookup2.txt" to remote directory started.
. 2009-08-21 06:37:49.511 Ascii transfer mode selected.
. 2009-08-21 06:37:49.511 Opening remote file.
> 2009-08-21 06:37:49.511 Type: SSH_FXP_OPEN, Size: 54, Number: 11164419
< 2009-08-21 06:37:49.511 Type: SSH_FXP_HANDLE, Size: 17, Number: 11164419
> 2009-08-21 06:37:49.511 Type: SSH_FXP_WRITE, Size: 424, Number: 11164934
> 2009-08-21 06:37:49.527 Type: SSH_FXP_CLOSE, Size: 17, Number: 11165188
> 2009-08-21 06:37:49.527 Type: SSH_FXP_SETSTAT, Size: 50, Number: 11164681
< 2009-08-21 06:37:49.527 Type: SSH_FXP_STATUS, Size: 21, Number: 11164934
< 2009-08-21 06:37:49.527 Type: SSH_FXP_STATUS, Size: 21, Number: 11165188
< 2009-08-21 06:37:49.527 Status/error code: 0
< 2009-08-21 06:37:49.527 Type: SSH_FXP_STATUS, Size: 21, Number: 11164681
. 2009-08-21 06:37:49.527 File: "E:\SMT_MIL\data\bos_plan_gift_type.txt"
. 2009-08-21 06:37:49.542 Copying "E:\SMT_MIL\data\bos_plan_gift_type.txt" to remote directory started.
. 2009-08-21 06:37:49.542 Ascii transfer mode selected.
. 2009-08-21 06:37:49.542 Opening remote file.
> 2009-08-21 06:37:49.542 Type: SSH_FXP_OPEN, Size: 48, Number: 11165443
< 2009-08-21 06:37:49.542 Type: SSH_FXP_HANDLE, Size: 17, Number: 11165443
> 2009-08-21 06:37:49.542 Type: SSH_FXP_WRITE, Size: 424, Number: 11165958
> 2009-08-21 06:37:49.542 Type: SSH_FXP_CLOSE, Size: 17, Number: 11166212
> 2009-08-21 06:37:49.542 Type: SSH_FXP_SETSTAT, Size: 44, Number: 11165705
< 2009-08-21 06:37:49.542 Type: SSH_FXP_STATUS, Size: 21, Number: 11165958
< 2009-08-21 06:37:49.542 Type: SSH_FXP_STATUS, Size: 21, Number: 11166212
< 2009-08-21 06:37:49.542 Status/error code: 0
< 2009-08-21 06:37:49.542 Type: SSH_FXP_STATUS, Size: 21, Number: 11165705
. 2009-08-21 06:37:49.558 File: "E:\SMT_MIL\data\bos_school.txt"
. 2009-08-21 06:37:49.558 Copying "E:\SMT_MIL\data\bos_school.txt" to remote directory started.
. 2009-08-21 06:37:49.558 Ascii transfer mode selected.
. 2009-08-21 06:37:49.558 Opening remote file.
> 2009-08-21 06:37:49.558 Type: SSH_FXP_OPEN, Size: 40, Number: 11166467
< 2009-08-21 06:37:49.558 Type: SSH_FXP_HANDLE, Size: 17, Number: 11166467
> 2009-08-21 06:37:49.589 Type: SSH_FXP_WRITE, Size: 16333, Number: 11166982
. 2009-08-21 06:38:11.730 4197 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:38:11.730 Type: SSH_FXP_CLOSE, Size: 17, Number: 11704836
> 2009-08-21 06:38:11.730 Type: SSH_FXP_SETSTAT, Size: 36, Number: 11166729
< 2009-08-21 06:38:11.761 Type: SSH_FXP_STATUS, Size: 21, Number: 11703814
< 2009-08-21 06:38:11.761 Type: SSH_FXP_STATUS, Size: 21, Number: 11704070
< 2009-08-21 06:38:11.761 Type: SSH_FXP_STATUS, Size: 21, Number: 11704326
< 2009-08-21 06:38:11.948 Type: SSH_FXP_STATUS, Size: 21, Number: 11704582
< 2009-08-21 06:38:11.948 Type: SSH_FXP_STATUS, Size: 21, Number: 11704836
< 2009-08-21 06:38:11.948 Status/error code: 0
< 2009-08-21 06:38:11.948 Type: SSH_FXP_STATUS, Size: 21, Number: 11166729
. 2009-08-21 06:38:11.948 File: "E:\SMT_MIL\data\bos_school_names.txt"
. 2009-08-21 06:38:11.948 Copying "E:\SMT_MIL\data\bos_school_names.txt" to remote directory started.
. 2009-08-21 06:38:11.948 Ascii transfer mode selected.
. 2009-08-21 06:38:11.948 Opening remote file.
> 2009-08-21 06:38:11.948 Type: SSH_FXP_OPEN, Size: 46, Number: 11705091
< 2009-08-21 06:38:11.948 Type: SSH_FXP_HANDLE, Size: 17, Number: 11705091
> 2009-08-21 06:38:11.964 Type: SSH_FXP_WRITE, Size: 3151, Number: 11705606
> 2009-08-21 06:38:11.964 Type: SSH_FXP_CLOSE, Size: 17, Number: 11705860
> 2009-08-21 06:38:11.964 Type: SSH_FXP_SETSTAT, Size: 42, Number: 11705353
< 2009-08-21 06:38:11.964 Type: SSH_FXP_STATUS, Size: 21, Number: 11705606
< 2009-08-21 06:38:12.167 Type: SSH_FXP_STATUS, Size: 21, Number: 11705860
< 2009-08-21 06:38:12.167 Status/error code: 0
< 2009-08-21 06:38:12.167 Type: SSH_FXP_STATUS, Size: 21, Number: 11705353
. 2009-08-21 06:38:12.167 File: "E:\SMT_MIL\data\bos_tender.txt"
. 2009-08-21 06:38:12.167 Copying "E:\SMT_MIL\data\bos_tender.txt" to remote directory started.
. 2009-08-21 06:38:12.167 Ascii transfer mode selected.
. 2009-08-21 06:38:12.167 Opening remote file.
> 2009-08-21 06:38:12.167 Type: SSH_FXP_OPEN, Size: 40, Number: 11706115
< 2009-08-21 06:38:12.167 Type: SSH_FXP_HANDLE, Size: 17, Number: 11706115
> 2009-08-21 06:38:12.167 Type: SSH_FXP_WRITE, Size: 3557, Number: 11706630
> 2009-08-21 06:38:12.167 Type: SSH_FXP_CLOSE, Size: 17, Number: 11706884
> 2009-08-21 06:38:12.183 Type: SSH_FXP_SETSTAT, Size: 36, Number: 11706377
< 2009-08-21 06:38:12.183 Type: SSH_FXP_STATUS, Size: 21, Number: 11706630
< 2009-08-21 06:38:12.386 Type: SSH_FXP_STATUS, Size: 21, Number: 11706884
< 2009-08-21 06:38:12.386 Status/error code: 0
< 2009-08-21 06:38:12.386 Type: SSH_FXP_STATUS, Size: 21, Number: 11706377
. 2009-08-21 06:38:12.401 File: "E:\SMT_MIL\data\DartmouthHarrisOLC.txt"
. 2009-08-21 06:38:12.401 Copying "E:\SMT_MIL\data\DartmouthHarrisOLC.txt" to remote directory started.
. 2009-08-21 06:38:12.401 Ascii transfer mode selected.
. 2009-08-21 06:38:12.401 Opening remote file.
> 2009-08-21 06:38:12.401 Type: SSH_FXP_OPEN, Size: 48, Number: 11707139
< 2009-08-21 06:38:12.417 Type: SSH_FXP_HANDLE, Size: 17, Number: 11707139
> 2009-08-21 06:38:12.433 Type: SSH_FXP_WRITE, Size: 16377, Number: 11707654
. 2009-08-21 06:38:12.448 5 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:38:12.464 Type: SSH_FXP_CLOSE, Size: 17, Number: 11708932
> 2009-08-21 06:38:12.464 Type: SSH_FXP_SETSTAT, Size: 44, Number: 11707401
< 2009-08-21 06:38:12.480 Type: SSH_FXP_STATUS, Size: 21, Number: 11707910
< 2009-08-21 06:38:12.605 Type: SSH_FXP_STATUS, Size: 21, Number: 11708166
< 2009-08-21 06:38:12.605 Type: SSH_FXP_STATUS, Size: 21, Number: 11708422
< 2009-08-21 06:38:12.605 Type: SSH_FXP_STATUS, Size: 21, Number: 11708678
< 2009-08-21 06:38:12.605 Type: SSH_FXP_STATUS, Size: 21, Number: 11708932
< 2009-08-21 06:38:12.605 Status/error code: 0
< 2009-08-21 06:38:12.605 Type: SSH_FXP_STATUS, Size: 21, Number: 11707401
. 2009-08-21 06:38:12.620 File: "E:\SMT_MIL\data\dar_account_cae.txt"
. 2009-08-21 06:38:12.620 Copying "E:\SMT_MIL\data\dar_account_cae.txt" to remote directory started.
. 2009-08-21 06:38:12.636 Ascii transfer mode selected.
. 2009-08-21 06:38:12.636 Opening remote file.
> 2009-08-21 06:38:12.636 Type: SSH_FXP_OPEN, Size: 45, Number: 11709187
< 2009-08-21 06:38:12.636 Type: SSH_FXP_HANDLE, Size: 17, Number: 11709187
> 2009-08-21 06:38:12.636 Type: SSH_FXP_WRITE, Size: 5762, Number: 11709702
> 2009-08-21 06:38:12.651 Type: SSH_FXP_CLOSE, Size: 17, Number: 11709956
> 2009-08-21 06:38:12.651 Type: SSH_FXP_SETSTAT, Size: 41, Number: 11709449
< 2009-08-21 06:38:12.651 Type: SSH_FXP_STATUS, Size: 21, Number: 11709702
< 2009-08-21 06:38:12.823 Type: SSH_FXP_STATUS, Size: 21, Number: 11709956
< 2009-08-21 06:38:12.823 Status/error code: 0
< 2009-08-21 06:38:12.823 Type: SSH_FXP_STATUS, Size: 21, Number: 11709449
. 2009-08-21 06:38:12.855 File: "E:\SMT_MIL\data\dar_address.txt"
. 2009-08-21 06:38:12.870 Copying "E:\SMT_MIL\data\dar_address.txt" to remote directory started.
. 2009-08-21 06:38:12.870 Ascii transfer mode selected.
. 2009-08-21 06:38:12.870 Opening remote file.
> 2009-08-21 06:38:12.870 Type: SSH_FXP_OPEN, Size: 41, Number: 11710211
< 2009-08-21 06:38:12.870 Type: SSH_FXP_HANDLE, Size: 17, Number: 11710211
> 2009-08-21 06:38:12.886 Type: SSH_FXP_WRITE, Size: 16365, Number: 11710726
. 2009-08-21 06:39:38.901 16483 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:39:38.963 Type: SSH_FXP_CLOSE, Size: 17, Number: 13821188
< 2009-08-21 06:39:38.963 Type: SSH_FXP_STATUS, Size: 21, Number: 13820166
< 2009-08-21 06:39:38.963 Status/error code: 0
> 2009-08-21 06:39:38.963 Type: SSH_FXP_SETSTAT, Size: 37, Number: 11710473
< 2009-08-21 06:39:38.963 Type: SSH_FXP_STATUS, Size: 21, Number: 13820422
< 2009-08-21 06:39:38.979 Type: SSH_FXP_STATUS, Size: 21, Number: 13820678
< 2009-08-21 06:39:39.120 Type: SSH_FXP_STATUS, Size: 21, Number: 13820934
< 2009-08-21 06:39:39.120 Type: SSH_FXP_STATUS, Size: 21, Number: 13821188
< 2009-08-21 06:39:39.120 Status/error code: 0
< 2009-08-21 06:39:39.120 Type: SSH_FXP_STATUS, Size: 21, Number: 11710473
. 2009-08-21 06:39:39.120 File: "E:\SMT_MIL\data\dar_address_types.txt"
. 2009-08-21 06:39:39.120 Copying "E:\SMT_MIL\data\dar_address_types.txt" to remote directory started.
. 2009-08-21 06:39:39.120 Ascii transfer mode selected.
. 2009-08-21 06:39:39.120 Opening remote file.
> 2009-08-21 06:39:39.120 Type: SSH_FXP_OPEN, Size: 47, Number: 13821443
< 2009-08-21 06:39:39.135 Type: SSH_FXP_HANDLE, Size: 17, Number: 13821443
> 2009-08-21 06:39:39.151 Type: SSH_FXP_WRITE, Size: 4143, Number: 13821958
> 2009-08-21 06:39:39.151 Type: SSH_FXP_CLOSE, Size: 17, Number: 13822212
> 2009-08-21 06:39:39.151 Type: SSH_FXP_SETSTAT, Size: 43, Number: 13821705
< 2009-08-21 06:39:39.151 Type: SSH_FXP_STATUS, Size: 21, Number: 13821958
< 2009-08-21 06:39:39.338 Type: SSH_FXP_STATUS, Size: 21, Number: 13822212
< 2009-08-21 06:39:39.338 Status/error code: 0
< 2009-08-21 06:39:39.338 Type: SSH_FXP_STATUS, Size: 21, Number: 13821705
. 2009-08-21 06:39:39.354 File: "E:\SMT_MIL\data\dar_attribute.txt"
. 2009-08-21 06:39:39.385 Copying "E:\SMT_MIL\data\dar_attribute.txt" to remote directory started.
. 2009-08-21 06:39:39.385 Ascii transfer mode selected.
. 2009-08-21 06:39:39.385 Opening remote file.
> 2009-08-21 06:39:39.385 Type: SSH_FXP_OPEN, Size: 43, Number: 13822467
< 2009-08-21 06:39:39.385 Type: SSH_FXP_HANDLE, Size: 17, Number: 13822467
> 2009-08-21 06:39:39.401 Type: SSH_FXP_WRITE, Size: 16328, Number: 13822982
. 2009-08-21 06:39:51.807 2315 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:39:51.807 Type: SSH_FXP_CLOSE, Size: 17, Number: 14119940
> 2009-08-21 06:39:51.807 Type: SSH_FXP_SETSTAT, Size: 39, Number: 13822729
< 2009-08-21 06:39:51.807 Type: SSH_FXP_STATUS, Size: 21, Number: 14118918
< 2009-08-21 06:39:51.823 Type: SSH_FXP_STATUS, Size: 21, Number: 14119174
< 2009-08-21 06:39:51.823 Type: SSH_FXP_STATUS, Size: 21, Number: 14119430
< 2009-08-21 06:39:52.026 Type: SSH_FXP_STATUS, Size: 21, Number: 14119686
< 2009-08-21 06:39:52.026 Type: SSH_FXP_STATUS, Size: 21, Number: 14119940
< 2009-08-21 06:39:52.026 Status/error code: 0
< 2009-08-21 06:39:52.026 Type: SSH_FXP_STATUS, Size: 21, Number: 13822729
. 2009-08-21 06:39:52.041 File: "E:\SMT_MIL\data\dar_attribute_types.txt"
. 2009-08-21 06:39:52.057 Copying "E:\SMT_MIL\data\dar_attribute_types.txt" to remote directory started.
. 2009-08-21 06:39:52.057 Ascii transfer mode selected.
. 2009-08-21 06:39:52.057 Opening remote file.
> 2009-08-21 06:39:52.057 Type: SSH_FXP_OPEN, Size: 49, Number: 14120195
< 2009-08-21 06:39:52.057 Type: SSH_FXP_HANDLE, Size: 17, Number: 14120195
> 2009-08-21 06:39:52.073 Type: SSH_FXP_WRITE, Size: 16313, Number: 14120710
. 2009-08-21 06:39:52.104 5 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:39:52.104 Type: SSH_FXP_CLOSE, Size: 17, Number: 14121988
> 2009-08-21 06:39:52.104 Type: SSH_FXP_SETSTAT, Size: 45, Number: 14120457
< 2009-08-21 06:39:52.120 Type: SSH_FXP_STATUS, Size: 21, Number: 14120966
< 2009-08-21 06:39:52.120 Type: SSH_FXP_STATUS, Size: 21, Number: 14121222
< 2009-08-21 06:39:52.120 Type: SSH_FXP_STATUS, Size: 21, Number: 14121478
< 2009-08-21 06:39:52.245 Type: SSH_FXP_STATUS, Size: 21, Number: 14121734
< 2009-08-21 06:39:52.245 Type: SSH_FXP_STATUS, Size: 21, Number: 14121988
< 2009-08-21 06:39:52.245 Status/error code: 0
< 2009-08-21 06:39:52.245 Type: SSH_FXP_STATUS, Size: 21, Number: 14120457
. 2009-08-21 06:39:52.245 File: "E:\SMT_MIL\data\dar_cae_categories.txt"
. 2009-08-21 06:39:52.245 Copying "E:\SMT_MIL\data\dar_cae_categories.txt" to remote directory started.
. 2009-08-21 06:39:52.245 Ascii transfer mode selected.
. 2009-08-21 06:39:52.245 Opening remote file.
> 2009-08-21 06:39:52.245 Type: SSH_FXP_OPEN, Size: 48, Number: 14122243
< 2009-08-21 06:39:52.245 Type: SSH_FXP_HANDLE, Size: 17, Number: 14122243
> 2009-08-21 06:39:52.260 Type: SSH_FXP_WRITE, Size: 2908, Number: 14122758
> 2009-08-21 06:39:52.260 Type: SSH_FXP_CLOSE, Size: 17, Number: 14123012
> 2009-08-21 06:39:52.260 Type: SSH_FXP_SETSTAT, Size: 44, Number: 14122505
< 2009-08-21 06:39:52.260 Type: SSH_FXP_STATUS, Size: 21, Number: 14122758
< 2009-08-21 06:39:52.260 Type: SSH_FXP_STATUS, Size: 21, Number: 14123012
< 2009-08-21 06:39:52.260 Status/error code: 0
< 2009-08-21 06:39:52.463 Type: SSH_FXP_STATUS, Size: 21, Number: 14122505
< 2009-08-21 06:39:52.463 Status/error code: 0
. 2009-08-21 06:39:52.479 File: "E:\SMT_MIL\data\dar_campaigns.txt"
. 2009-08-21 06:39:52.495 Copying "E:\SMT_MIL\data\dar_campaigns.txt" to remote directory started.
. 2009-08-21 06:39:52.495 Ascii transfer mode selected.
. 2009-08-21 06:39:52.495 Opening remote file.
> 2009-08-21 06:39:52.495 Type: SSH_FXP_OPEN, Size: 43, Number: 14123267
< 2009-08-21 06:39:52.495 Type: SSH_FXP_HANDLE, Size: 17, Number: 14123267
> 2009-08-21 06:39:52.510 Type: SSH_FXP_WRITE, Size: 3794, Number: 14123782
> 2009-08-21 06:39:52.510 Type: SSH_FXP_CLOSE, Size: 17, Number: 14124036
> 2009-08-21 06:39:52.510 Type: SSH_FXP_SETSTAT, Size: 39, Number: 14123529
< 2009-08-21 06:39:52.526 Type: SSH_FXP_STATUS, Size: 21, Number: 14123782
< 2009-08-21 06:39:52.682 Type: SSH_FXP_STATUS, Size: 21, Number: 14124036
< 2009-08-21 06:39:52.682 Status/error code: 0
< 2009-08-21 06:39:52.682 Type: SSH_FXP_STATUS, Size: 21, Number: 14123529
. 2009-08-21 06:39:52.682 File: "E:\SMT_MIL\data\dar_campaign_goals.txt"
. 2009-08-21 06:39:52.698 Copying "E:\SMT_MIL\data\dar_campaign_goals.txt" to remote directory started.
. 2009-08-21 06:39:52.698 Ascii transfer mode selected.
. 2009-08-21 06:39:52.698 Opening remote file.
> 2009-08-21 06:39:52.698 Type: SSH_FXP_OPEN, Size: 48, Number: 14124291
< 2009-08-21 06:39:52.698 Type: SSH_FXP_HANDLE, Size: 17, Number: 14124291
> 2009-08-21 06:39:52.713 Type: SSH_FXP_WRITE, Size: 2286, Number: 14124806
> 2009-08-21 06:39:52.713 Type: SSH_FXP_CLOSE, Size: 17, Number: 14125060
> 2009-08-21 06:39:52.713 Type: SSH_FXP_SETSTAT, Size: 44, Number: 14124553
< 2009-08-21 06:39:52.713 Type: SSH_FXP_STATUS, Size: 21, Number: 14124806
< 2009-08-21 06:39:52.713 Type: SSH_FXP_STATUS, Size: 21, Number: 14125060
< 2009-08-21 06:39:52.713 Status/error code: 0
< 2009-08-21 06:39:52.713 Type: SSH_FXP_STATUS, Size: 21, Number: 14124553
. 2009-08-21 06:39:52.713 File: "E:\SMT_MIL\data\dar_chart_of_accounts.txt"
. 2009-08-21 06:39:52.713 Copying "E:\SMT_MIL\data\dar_chart_of_accounts.txt" to remote directory started.
. 2009-08-21 06:39:52.713 Ascii transfer mode selected.
. 2009-08-21 06:39:52.713 Opening remote file.
> 2009-08-21 06:39:52.713 Type: SSH_FXP_OPEN, Size: 51, Number: 14125315
< 2009-08-21 06:39:52.729 Type: SSH_FXP_HANDLE, Size: 17, Number: 14125315
> 2009-08-21 06:39:52.729 Type: SSH_FXP_WRITE, Size: 16345, Number: 14125830
. 2009-08-21 06:39:53.010 49 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:39:53.010 Type: SSH_FXP_CLOSE, Size: 17, Number: 14132740
> 2009-08-21 06:39:53.010 Type: SSH_FXP_SETSTAT, Size: 47, Number: 14125577
< 2009-08-21 06:39:53.026 Type: SSH_FXP_STATUS, Size: 21, Number: 14131718
< 2009-08-21 06:39:53.026 Type: SSH_FXP_STATUS, Size: 21, Number: 14131974
< 2009-08-21 06:39:53.229 Type: SSH_FXP_STATUS, Size: 21, Number: 14132230
< 2009-08-21 06:39:53.229 Type: SSH_FXP_STATUS, Size: 21, Number: 14132486
< 2009-08-21 06:39:53.229 Type: SSH_FXP_STATUS, Size: 21, Number: 14132740
< 2009-08-21 06:39:53.229 Status/error code: 0
< 2009-08-21 06:39:53.229 Type: SSH_FXP_STATUS, Size: 21, Number: 14125577
. 2009-08-21 06:39:53.229 File: "E:\SMT_MIL\data\dar_constituent_types.txt"
. 2009-08-21 06:39:53.245 Copying "E:\SMT_MIL\data\dar_constituent_types.txt" to remote directory started.
. 2009-08-21 06:39:53.245 Ascii transfer mode selected.
. 2009-08-21 06:39:53.245 Opening remote file.
> 2009-08-21 06:39:53.245 Type: SSH_FXP_OPEN, Size: 51, Number: 14132995
< 2009-08-21 06:39:53.245 Type: SSH_FXP_HANDLE, Size: 17, Number: 14132995
> 2009-08-21 06:39:53.260 Type: SSH_FXP_WRITE, Size: 10871, Number: 14133510
> 2009-08-21 06:39:53.260 Type: SSH_FXP_CLOSE, Size: 17, Number: 14133764
> 2009-08-21 06:39:53.260 Type: SSH_FXP_SETSTAT, Size: 47, Number: 14133257
< 2009-08-21 06:39:53.276 Type: SSH_FXP_STATUS, Size: 21, Number: 14133510
< 2009-08-21 06:39:53.291 Type: SSH_FXP_STATUS, Size: 21, Number: 14133764
< 2009-08-21 06:39:53.291 Status/error code: 0
< 2009-08-21 06:39:53.291 Type: SSH_FXP_STATUS, Size: 21, Number: 14133257
. 2009-08-21 06:39:53.307 File: "E:\SMT_MIL\data\dar_corebio.txt"
. 2009-08-21 06:39:53.323 Copying "E:\SMT_MIL\data\dar_corebio.txt" to remote directory started.
. 2009-08-21 06:39:53.323 Ascii transfer mode selected.
. 2009-08-21 06:39:53.323 Opening remote file.
> 2009-08-21 06:39:53.323 Type: SSH_FXP_OPEN, Size: 41, Number: 14134019
< 2009-08-21 06:39:53.323 Type: SSH_FXP_HANDLE, Size: 17, Number: 14134019
> 2009-08-21 06:39:53.338 Type: SSH_FXP_WRITE, Size: 16368, Number: 14134534
. 2009-08-21 06:40:45.041 Initiating key re-exchange (too much data sent)
. 2009-08-21 06:40:45.072 Using Diffie-Hellman with standard group "group1"
. 2009-08-21 06:40:45.072 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-08-21 06:40:45.463 Initialised AES-256 CBC client->server encryption
. 2009-08-21 06:40:45.463 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-08-21 06:40:45.994 Initialised AES-256 CBC server->client encryption
. 2009-08-21 06:40:45.994 Initialised HMAC-SHA1 server->client MAC algorithm
. 2009-08-21 06:40:52.947 11274 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:40:52.963 Type: SSH_FXP_CLOSE, Size: 17, Number: 15578372
< 2009-08-21 06:40:52.963 Type: SSH_FXP_STATUS, Size: 21, Number: 15577094
< 2009-08-21 06:40:52.963 Status/error code: 0
> 2009-08-21 06:40:52.963 Type: SSH_FXP_SETSTAT, Size: 37, Number: 14134281
< 2009-08-21 06:40:52.979 Type: SSH_FXP_STATUS, Size: 21, Number: 15577350
< 2009-08-21 06:40:53.166 Type: SSH_FXP_STATUS, Size: 21, Number: 15577606
< 2009-08-21 06:40:53.166 Type: SSH_FXP_STATUS, Size: 21, Number: 15577862
< 2009-08-21 06:40:53.166 Type: SSH_FXP_STATUS, Size: 21, Number: 15578118
< 2009-08-21 06:40:53.166 Type: SSH_FXP_STATUS, Size: 21, Number: 15578372
< 2009-08-21 06:40:53.166 Status/error code: 0
< 2009-08-21 06:40:53.166 Type: SSH_FXP_STATUS, Size: 21, Number: 14134281
. 2009-08-21 06:40:53.166 File: "E:\SMT_MIL\data\dar_death.txt"
. 2009-08-21 06:40:53.166 Copying "E:\SMT_MIL\data\dar_death.txt" to remote directory started.
. 2009-08-21 06:40:53.166 Ascii transfer mode selected.
. 2009-08-21 06:40:53.166 Opening remote file.
> 2009-08-21 06:40:53.166 Type: SSH_FXP_OPEN, Size: 39, Number: 15578627
< 2009-08-21 06:40:53.182 Type: SSH_FXP_HANDLE, Size: 17, Number: 15578627
> 2009-08-21 06:40:53.182 Type: SSH_FXP_WRITE, Size: 16330, Number: 15579142
. 2009-08-21 06:40:53.650 89 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:40:53.650 Type: SSH_FXP_CLOSE, Size: 17, Number: 15591172
> 2009-08-21 06:40:53.650 Type: SSH_FXP_SETSTAT, Size: 35, Number: 15578889
< 2009-08-21 06:40:53.650 Type: SSH_FXP_STATUS, Size: 21, Number: 15590150
< 2009-08-21 06:40:53.682 Type: SSH_FXP_STATUS, Size: 21, Number: 15590406
< 2009-08-21 06:40:53.682 Type: SSH_FXP_STATUS, Size: 21, Number: 15590662
< 2009-08-21 06:40:53.822 Type: SSH_FXP_STATUS, Size: 21, Number: 15590918
< 2009-08-21 06:40:53.822 Type: SSH_FXP_STATUS, Size: 21, Number: 15591172
< 2009-08-21 06:40:53.822 Status/error code: 0
< 2009-08-21 06:40:53.822 Type: SSH_FXP_STATUS, Size: 21, Number: 15578889
. 2009-08-21 06:40:53.838 File: "E:\SMT_MIL\data\dar_degrees.txt"
. 2009-08-21 06:40:53.838 Copying "E:\SMT_MIL\data\dar_degrees.txt" to remote directory started.
. 2009-08-21 06:40:53.838 Ascii transfer mode selected.
. 2009-08-21 06:40:53.838 Opening remote file.
> 2009-08-21 06:40:53.838 Type: SSH_FXP_OPEN, Size: 41, Number: 15591427
< 2009-08-21 06:40:53.854 Type: SSH_FXP_HANDLE, Size: 17, Number: 15591427
> 2009-08-21 06:40:53.854 Type: SSH_FXP_WRITE, Size: 6876, Number: 15591942
> 2009-08-21 06:40:53.869 Type: SSH_FXP_CLOSE, Size: 17, Number: 15592196
> 2009-08-21 06:40:53.869 Type: SSH_FXP_SETSTAT, Size: 37, Number: 15591689
< 2009-08-21 06:40:53.869 Type: SSH_FXP_STATUS, Size: 21, Number: 15591942
< 2009-08-21 06:40:53.869 Type: SSH_FXP_STATUS, Size: 21, Number: 15592196
< 2009-08-21 06:40:53.869 Status/error code: 0
< 2009-08-21 06:40:53.869 Type: SSH_FXP_STATUS, Size: 21, Number: 15591689
. 2009-08-21 06:40:53.916 File: "E:\SMT_MIL\data\dar_gifts.txt"
. 2009-08-21 06:40:53.932 Copying "E:\SMT_MIL\data\dar_gifts.txt" to remote directory started.
. 2009-08-21 06:40:53.932 Ascii transfer mode selected.
. 2009-08-21 06:40:53.932 Opening remote file.
> 2009-08-21 06:40:53.932 Type: SSH_FXP_OPEN, Size: 39, Number: 15592451
< 2009-08-21 06:40:53.932 Type: SSH_FXP_HANDLE, Size: 17, Number: 15592451
> 2009-08-21 06:40:53.947 Type: SSH_FXP_WRITE, Size: 16365, Number: 15592966
. 2009-08-21 06:44:09.134 36899 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:44:09.134 Type: SSH_FXP_CLOSE, Size: 17, Number: 20316676
> 2009-08-21 06:44:09.134 Type: SSH_FXP_SETSTAT, Size: 35, Number: 15592713
< 2009-08-21 06:44:09.149 Type: SSH_FXP_STATUS, Size: 21, Number: 20315654
< 2009-08-21 06:44:09.274 Type: SSH_FXP_STATUS, Size: 21, Number: 20315910
< 2009-08-21 06:44:09.290 Type: SSH_FXP_STATUS, Size: 21, Number: 20316166
< 2009-08-21 06:44:09.290 Type: SSH_FXP_STATUS, Size: 21, Number: 20316422
< 2009-08-21 06:44:09.290 Type: SSH_FXP_STATUS, Size: 21, Number: 20316676
< 2009-08-21 06:44:09.290 Status/error code: 0
< 2009-08-21 06:44:09.290 Type: SSH_FXP_STATUS, Size: 21, Number: 15592713
. 2009-08-21 06:44:09.290 File: "E:\SMT_MIL\data\dar_gift_types.txt"
. 2009-08-21 06:44:09.321 Copying "E:\SMT_MIL\data\dar_gift_types.txt" to remote directory started.
. 2009-08-21 06:44:09.321 Ascii transfer mode selected.
. 2009-08-21 06:44:09.321 Opening remote file.
> 2009-08-21 06:44:09.321 Type: SSH_FXP_OPEN, Size: 44, Number: 20316931
< 2009-08-21 06:44:09.321 Type: SSH_FXP_HANDLE, Size: 17, Number: 20316931
> 2009-08-21 06:44:09.337 Type: SSH_FXP_WRITE, Size: 7860, Number: 20317446
> 2009-08-21 06:44:09.352 Type: SSH_FXP_CLOSE, Size: 17, Number: 20317700
> 2009-08-21 06:44:09.352 Type: SSH_FXP_SETSTAT, Size: 40, Number: 20317193
< 2009-08-21 06:44:09.352 Type: SSH_FXP_STATUS, Size: 21, Number: 20317446
< 2009-08-21 06:44:09.352 Type: SSH_FXP_STATUS, Size: 21, Number: 20317700
< 2009-08-21 06:44:09.352 Status/error code: 0
< 2009-08-21 06:44:09.352 Type: SSH_FXP_STATUS, Size: 21, Number: 20317193
. 2009-08-21 06:44:09.352 File: "E:\SMT_MIL\data\dar_institutions.txt"
. 2009-08-21 06:44:09.352 Copying "E:\SMT_MIL\data\dar_institutions.txt" to remote directory started.
. 2009-08-21 06:44:09.352 Ascii transfer mode selected.
. 2009-08-21 06:44:09.352 Opening remote file.
> 2009-08-21 06:44:09.352 Type: SSH_FXP_OPEN, Size: 46, Number: 20317955
< 2009-08-21 06:44:09.352 Type: SSH_FXP_HANDLE, Size: 17, Number: 20317955
> 2009-08-21 06:44:09.368 Type: SSH_FXP_WRITE, Size: 16292, Number: 20318470
. 2009-08-21 06:44:09.384 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:44:09.384 Type: SSH_FXP_CLOSE, Size: 17, Number: 20318980
> 2009-08-21 06:44:09.384 Type: SSH_FXP_SETSTAT, Size: 42, Number: 20318217
< 2009-08-21 06:44:09.399 Type: SSH_FXP_STATUS, Size: 21, Number: 20318470
< 2009-08-21 06:44:09.399 Type: SSH_FXP_STATUS, Size: 21, Number: 20318726
< 2009-08-21 06:44:09.399 Type: SSH_FXP_STATUS, Size: 21, Number: 20318980
< 2009-08-21 06:44:09.399 Status/error code: 0
< 2009-08-21 06:44:09.399 Type: SSH_FXP_STATUS, Size: 21, Number: 20318217
. 2009-08-21 06:44:09.399 File: "E:\SMT_MIL\data\dar_mill.txt"
. 2009-08-21 06:44:09.430 Copying "E:\SMT_MIL\data\dar_mill.txt" to remote directory started.
. 2009-08-21 06:44:09.430 Ascii transfer mode selected.
. 2009-08-21 06:44:09.430 Opening remote file.
> 2009-08-21 06:44:09.430 Type: SSH_FXP_OPEN, Size: 38, Number: 20319235
< 2009-08-21 06:44:09.430 Type: SSH_FXP_HANDLE, Size: 17, Number: 20319235
> 2009-08-21 06:44:09.430 Type: SSH_FXP_WRITE, Size: 53, Number: 20319750
> 2009-08-21 06:44:09.430 Type: SSH_FXP_CLOSE, Size: 17, Number: 20320004
> 2009-08-21 06:44:09.430 Type: SSH_FXP_SETSTAT, Size: 34, Number: 20319497
< 2009-08-21 06:44:09.430 Type: SSH_FXP_STATUS, Size: 21, Number: 20319750
< 2009-08-21 06:44:09.446 Type: SSH_FXP_STATUS, Size: 21, Number: 20320004
< 2009-08-21 06:44:09.446 Status/error code: 0
< 2009-08-21 06:44:09.446 Type: SSH_FXP_STATUS, Size: 21, Number: 20319497
. 2009-08-21 06:44:09.462 File: "E:\SMT_MIL\data\dar_name.txt"
. 2009-08-21 06:44:09.462 Copying "E:\SMT_MIL\data\dar_name.txt" to remote directory started.
. 2009-08-21 06:44:09.462 Ascii transfer mode selected.
. 2009-08-21 06:44:09.462 Opening remote file.
> 2009-08-21 06:44:09.462 Type: SSH_FXP_OPEN, Size: 38, Number: 20320259
< 2009-08-21 06:44:09.462 Type: SSH_FXP_HANDLE, Size: 17, Number: 20320259
> 2009-08-21 06:44:09.477 Type: SSH_FXP_WRITE, Size: 16359, Number: 20320774
. 2009-08-21 06:44:54.227 8620 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:44:54.227 Type: SSH_FXP_CLOSE, Size: 17, Number: 21424644
> 2009-08-21 06:44:54.227 Type: SSH_FXP_SETSTAT, Size: 34, Number: 20320521
< 2009-08-21 06:44:54.227 Type: SSH_FXP_STATUS, Size: 21, Number: 21423878
< 2009-08-21 06:44:54.243 Type: SSH_FXP_STATUS, Size: 21, Number: 21424134
< 2009-08-21 06:44:54.446 Type: SSH_FXP_STATUS, Size: 21, Number: 21424390
< 2009-08-21 06:44:54.446 Type: SSH_FXP_STATUS, Size: 21, Number: 21424644
< 2009-08-21 06:44:54.446 Status/error code: 0
< 2009-08-21 06:44:54.446 Type: SSH_FXP_STATUS, Size: 21, Number: 20320521
. 2009-08-21 06:44:54.461 File: "E:\SMT_MIL\data\dar_plannedgifts.txt"
. 2009-08-21 06:44:54.477 Copying "E:\SMT_MIL\data\dar_plannedgifts.txt" to remote directory started.
. 2009-08-21 06:44:54.477 Ascii transfer mode selected.
. 2009-08-21 06:44:54.477 Opening remote file.
> 2009-08-21 06:44:54.477 Type: SSH_FXP_OPEN, Size: 46, Number: 21424899
< 2009-08-21 06:44:54.477 Type: SSH_FXP_HANDLE, Size: 17, Number: 21424899
> 2009-08-21 06:44:54.493 Type: SSH_FXP_WRITE, Size: 1165, Number: 21425414
> 2009-08-21 06:44:54.493 Type: SSH_FXP_CLOSE, Size: 17, Number: 21425668
> 2009-08-21 06:44:54.493 Type: SSH_FXP_SETSTAT, Size: 42, Number: 21425161
< 2009-08-21 06:44:54.524 Type: SSH_FXP_STATUS, Size: 21, Number: 21425414
< 2009-08-21 06:44:54.524 Type: SSH_FXP_STATUS, Size: 21, Number: 21425668
< 2009-08-21 06:44:54.524 Status/error code: 0
< 2009-08-21 06:44:54.524 Type: SSH_FXP_STATUS, Size: 21, Number: 21425161
. 2009-08-21 06:44:54.524 File: "E:\SMT_MIL\data\dar_plannedgifts_lookup2.txt"
. 2009-08-21 06:44:54.539 Copying "E:\SMT_MIL\data\dar_plannedgifts_lookup2.txt" to remote directory started.
. 2009-08-21 06:44:54.539 Ascii transfer mode selected.
. 2009-08-21 06:44:54.539 Opening remote file.
> 2009-08-21 06:44:54.539 Type: SSH_FXP_OPEN, Size: 54, Number: 21425923
< 2009-08-21 06:44:54.539 Type: SSH_FXP_HANDLE, Size: 17, Number: 21425923
> 2009-08-21 06:44:54.539 Type: SSH_FXP_WRITE, Size: 424, Number: 21426438
> 2009-08-21 06:44:54.539 Type: SSH_FXP_CLOSE, Size: 17, Number: 21426692
> 2009-08-21 06:44:54.539 Type: SSH_FXP_SETSTAT, Size: 50, Number: 21426185
< 2009-08-21 06:44:54.539 Type: SSH_FXP_STATUS, Size: 21, Number: 21426438
< 2009-08-21 06:44:54.555 Type: SSH_FXP_STATUS, Size: 21, Number: 21426692
< 2009-08-21 06:44:54.555 Status/error code: 0
< 2009-08-21 06:44:54.555 Type: SSH_FXP_STATUS, Size: 21, Number: 21426185
. 2009-08-21 06:44:54.555 File: "E:\SMT_MIL\data\dar_plan_gift_type.txt"
. 2009-08-21 06:44:54.555 Copying "E:\SMT_MIL\data\dar_plan_gift_type.txt" to remote directory started.
. 2009-08-21 06:44:54.555 Ascii transfer mode selected.
. 2009-08-21 06:44:54.555 Opening remote file.
> 2009-08-21 06:44:54.555 Type: SSH_FXP_OPEN, Size: 48, Number: 21426947
< 2009-08-21 06:44:54.555 Type: SSH_FXP_HANDLE, Size: 17, Number: 21426947
> 2009-08-21 06:44:54.555 Type: SSH_FXP_WRITE, Size: 424, Number: 21427462
> 2009-08-21 06:44:54.555 Type: SSH_FXP_CLOSE, Size: 17, Number: 21427716
> 2009-08-21 06:44:54.555 Type: SSH_FXP_SETSTAT, Size: 44, Number: 21427209
< 2009-08-21 06:44:54.555 Type: SSH_FXP_STATUS, Size: 21, Number: 21427462
< 2009-08-21 06:44:54.571 Type: SSH_FXP_STATUS, Size: 21, Number: 21427716
< 2009-08-21 06:44:54.571 Status/error code: 0
< 2009-08-21 06:44:54.571 Type: SSH_FXP_STATUS, Size: 21, Number: 21427209
. 2009-08-21 06:44:54.571 File: "E:\SMT_MIL\data\dar_school.txt"
. 2009-08-21 06:44:54.586 Copying "E:\SMT_MIL\data\dar_school.txt" to remote directory started.
. 2009-08-21 06:44:54.586 Ascii transfer mode selected.
. 2009-08-21 06:44:54.586 Opening remote file.
> 2009-08-21 06:44:54.586 Type: SSH_FXP_OPEN, Size: 40, Number: 21427971
< 2009-08-21 06:44:54.586 Type: SSH_FXP_HANDLE, Size: 17, Number: 21427971
> 2009-08-21 06:44:54.602 Type: SSH_FXP_WRITE, Size: 16333, Number: 21428486
. 2009-08-21 06:45:07.196 2183 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-08-21 06:45:07.196 Type: SSH_FXP_CLOSE, Size: 17, Number: 21708548
> 2009-08-21 06:45:07.196 Type: SSH_FXP_SETSTAT, Size: 36, Number: 21428233
< 2009-08-21 06:45:07.211 Type: SSH_FXP_STATUS, Size: 21, Number: 21707526
< 2009-08-21 06:45:07.352 Type: SSH_FXP_STATUS, Size: 21, Number: 21707782
< 2009-08-21 06:45:07.352 Type: SSH_FXP_STATUS, Size: 21, Number: 21708038
< 2009-08-21 06:45:07.352 Type: SSH_FXP_STATUS, Size: 21, Number: 21708294
< 2009-08-21 06:45:07.352 Type: SSH_FXP_STATUS, Size: 21, Number: 21708548
< 2009-08-21 06:45:07.352 Status/error code: 0
< 2009-08-21 06:45:07.352 Type: SSH_FXP_STATUS, Size: 21, Number: 21428233
. 2009-08-21 06:45:07.352 File: "E:\SMT_MIL\data\dar_school_names.txt"
. 2009-08-21 06:45:07.352 Copying "E:\SMT_MIL\data\dar_school_names.txt" to remote directory started.
. 2009-08-21 06:45:07.352 Ascii transfer mode selected.
. 2009-08-21 06:45:07.352 Opening remote file.
> 2009-08-21 06:45:07.352 Type: SSH_FXP_OPEN, Size: 46, Number: 21708803
< 2009-08-21 06:45:07.352 Type: SSH_FXP_HANDLE, Size: 17, Number: 21708803
> 2009-08-21 06:45:07.383 Type: SSH_FXP_WRITE, Size: 1848, Number: 21709318
> 2009-08-21 06:45:07.383 Type: SSH_FXP_CLOSE, Size: 17, Number: 21709572
> 2009-08-21 06:45:07.383 Type: SSH_FXP_SETSTAT, Size: 42, Number: 21709065
< 2009-08-21 06:45:07.383 Type: SSH_FXP_STATUS, Size: 21, Number: 21709318
< 2009-08-21 06:45:07.571 Type: SSH_FXP_STATUS, Size: 21, Number: 21709572
< 2009-08-21 06:45:07.571 Status/error code: 0
< 2009-08-21 06:45:07.571 Type: SSH_FXP_STATUS, Size: 21, Number: 21709065
. 2009-08-21 06:45:07.571 File: "E:\SMT_MIL\data\dar_tender.txt"
. 2009-08-21 06:45:07.571 Copying "E:\SMT_MIL\data\dar_tender.txt" to remote directory started.
. 2009-08-21 06:45:07.571 Ascii transfer mode selected.
. 2009-08-21 06:45:07.571 Opening remote file.
> 2009-08-21 06:45:07.571 Type: SSH_FXP_OPEN, Size: 40, Number: 21709827
< 2009-08-21 06:45:07.586 Type: SSH_FXP_HANDLE, Size: 17, Number: 21709827
> 2009-08-21 06:45:07.586 Type: SSH_FXP_WRITE, Size: 4836, Number: 21710342
> 2009-08-21 06:45:07.586 Type: SSH_FXP_CLOSE, Size: 17, Number: 21710596
> 2009-08-21 06:45:07.586 Type: SSH_FXP_SETSTAT, Size: 36, Number: 21710089
< 2009-08-21 06:45:07.602 Type: SSH_FXP_STATUS, Size: 21, Number: 21710342
< 2009-08-21 06:45:07.602 Type: SSH_FXP_STATUS, Size: 21, Number: 21710596
< 2009-08-21 06:45:07.602 Status/error code: 0
< 2009-08-21 06:45:07.789 Type: SSH_FXP_STATUS, Size: 21, Number: 21710089
< 2009-08-21 06:45:07.789 Status/error code: 0
. 2009-08-21 06:45:07.805 File: "E:\SMT_MIL\data\WorcesterHarrisOLC.txt"
. 2009-08-21 06:45:07.821 Copying "E:\SMT_MIL\data\WorcesterHarrisOLC.txt" to remote directory started.
. 2009-08-21 06:45:07.821 Ascii transfer mode selected.
. 2009-08-21 06:45:07.821 Opening remote file.
> 2009-08-21 06:45:07.821 Type: SSH_FXP_OPEN, Size: 48, Number: 21710851
< 2009-08-21 06:45:07.836 Type: SSH_FXP_HANDLE, Size: 17, Number: 21710851
> 2009-08-21 06:45:07.836 Type: SSH_FXP_WRITE, Size: 16377, Number: 21711366
. 2009-08-21 0
Re: SFTP upload process
What does it mean "never make it to the source"? Quickly scanning through the log I do not see any error.
