Topic "Invalid access to memory error message pops up"
satish
Version of WinSCP:4.2.3(Build 494)
OS : Windows XP SP3
Transfer protocol : SFTP
While trying to open terminal from WinSCP it first gives following message:
Confirm
Current SFTP-3 session does not support command you request. Separate shell session may be opened to process the command. Do you want to open separate shell session?
Note: The server must provide Unix-like shell and the shell must use same path syntax as current SFTP-3 session.
OK Cancel Help
Now click ok and you will observe following error message:
Error
OK Help
c0m4r
Same problem here.
WinSCP 4.2.3 (Build 494)
Windows Vista HP 32bit Up-to-date.
When I am trying to open terminal with SFTP protocol I am getting this error:
Thanks for your post. This bug is being tracked already.
c0m4r
Thank you, I'll be patiently looking forward for updates.
I am having the same issue trying to open terminal while connected via wireless to my iPhone. I tried reinstalling SSH on my iPhone, WinSCP on my two PCs to no avail. Please let us know if there is anything we can do to help resolve this problem.
It is resolved already. Just wait for the next release. Or downgrade to stable release 4.1.9.
Splinty
So where is next beta we verify that?
Sors mea Jesus!
Ricardo
http://winscp.net/forum/viewtopic.php?p=26200#26200
Splinty
Cool, perfect... Problem it seems has gone... Bu in comparison with previous beta it's impossible to move copy etс directories with international names (symbols) again...
Happiness where are You?
Sors mea Jesus!
Can you post a log from 4.2.3 showing how it works and from 4.2.4 showing how it does not?
cheemeng
hi, i'm getting the same errors as well. Anyone can assist on this?
What version? Have you tried the latest one?
Which of the following would indicate a memory error on the Post? A. 1** B. 2** C. 3** D. 4**. Thanks... Pls I need anwser ASAP. God bless U.
Jbdgoogle
dolphin516
My winscp version is 5.0.4. I use the "keep romote directory to date" command to put files. Recently, it will pop up "invalid access to memory" after some files have transfered. And I need to restart the software to solve it temporaryly.
