Topic "Wildcard use in scripts"
apurva
I am trying to get filename from different directories. To do that I am using the following command in my script
get "/abc/jkl/com?/stats" c:\logs\
Scenario is that there are folders by name com1, com2, com3 etc.. and I am interested only in the "stats" file in each directory.
The above command gives me
Error listing directory '/abc/jkl/com?'
I haven't even reached the second part of using Operation masks to store the several stats file as "stats.com1", "stats.com2" etc.
Using version 4.2.3 build 494
You cannot use file masks for directories in path, only for filenames.
apurva
Any other way I can accomplish this? pointers would help. I just don't want to download the whole folders for one file.
You can list the directories, parse it with some script to generate WinSCP script file for downloading specific files. See this example for similar task.
