Topic "Ordered listing"
First of all THANK YOU SO MUCH for this wonderful piece of program. It is really important for my work, and makes it way easier. Which is something to appreciate.
What I'm asking is a simple matter (I don't know if it is simple to implement or not, so excuse me if it is not). The issue is this: whenever you have a directory full of numbered files, if you pick "sort by name" column Winscp sorts them Ok until a new order of magnitude in the number is achieved. (eg, instead of 1, 2,...9, 10..etc, Winscp sorts them like 1, 10, 11..2, 3,...etc) I would like to avoid that. That issue is only on the host side. I use the Commander interface, and the Windows side is Ok.
Best regards and keep up the great work.
I believe it does not work on local side either, does it?
Anyway, This request is being tracked already.
You're right prikryl, it doesn't work on the local side either. My excuses. Embarassed . Thanks for the reply and congratulations on your work. WinSCP is definitely the best program of its kind.
