very wrong time remaining estimation
andy_t_roo
North Carolina, US
when there are files to be skipped winscp gives quite a wrong estimation of the remaining time
In the linked image it is listing 4 days remaining after taking 17 mins to copy 75% (and the last 25% was all skipped files so went by in about 4 mins)
I was copying a few Gb of data, told winscp to only copy newer. - out of the several thousand files, only a small number need updating.
It looks like when winscp skips a file it doesn't subtract the size of the file from the "total amount to be transferred" - that way if i copy 1 mb at 1 mb/s , and then skip the next 99 mb (taking 9 seconds to do so), it would estimate that the remaining 100mb will take 1000 seconds (10 seconds to transfer 1mb)
potentially better estimation methods:
[list=]1mb per second transferred while active, 100mb=100 seconds;
100 mb in 10 seconds, 100mb=another 10; (probably best - that automatically takes care of the individual file transfer overhead ignored below without having to note when you actually are and are not transferring data, as above.
I'm skipping 99% of the data, and copying at 1mb/s, so 100mb should take 1 second
[/list]
Either way, saying you have 4 days left, when the first 75% of the data took 17 mins is possibly wrong.
to get that image i had skipped about 50G of data -- (win scp seems slow when copying a large number of files (12k from the one folder), but thats a quibble, not a bug) -- the actual copying speed in that example was about 4000k/s. )
win_scp build 721, on win_xp connecting to a generic linux-x86_64 server, using SFTP
edit - "disable bbcode in this post" is not checked - it still doesn't do the img link or list.
montonero
Not sure if this is the same issue but I've seen an incorrect speed display in queue pane after the upload was delayed for several minutes due to an error.
Attached an animation with how WinSCP shows its speed (on the left) and real speed from Windows' resource monitor (on the right).
WinSCP version is 5.14.2 beta (Build 9079) but I believe I've seen this with older versions too.
Sorry for my late answer.
I have been trying to reproduce the problem, but unsuccessfully.
Can you give us step-by-step instructions?
A log file may help too (on logging level Debug 2).
